Usually I measure driver impedance just by sweeping with my function gen. It has 50ohm output impedance and to make the measurement easier I add 50ohms in series, so a total of 100ohms. I use a PC scope and with the peak hold on the FFT I get decent sweeps.
Question is: When having the high series resistance, and thus very low damping factor on the speaker driver, doesn't this shift fs up/down, make the Q appear larger than it is, etc?
Is it more accurate using a power amplifier with a very small value series resistor and then measure both the voltage and current?
Does it matter? Will either method be accurate enough?
The peak of resonance is affected by Q somewhat - at low Q it will shift a bit (as well as being harder to measure anyway). So low damping should be at an advantage for accurate determination of mechanical resonant frequency perhaps?
Anyway if you measure V, I and SPL over a slow frequency sweep you'll get the same information whatever the driving impedance.
