Construction Tips Construction techniques and tips
Reticulated Foam Speaker Grill
Thread Tools
Old 17th December 2020, 10:29 AM   #1
scottjoplin is offline scottjoplin  Wales
Banned
Default Reticulated Foam Speaker Grill
Does anyone know where I can get white reticulated foam suitable for making a speaker grill? The stuff used in pond filters appears suitable but I need it at least 450mm x 1100mm. It's for an IB subwoofer. Thanks.
Old 17th December 2020, 03:06 PM   #2
Galu is online now Galu  Scotland
Thought I had found something, but it's out of stock! What thickness are you looking for?
Old 17th December 2020, 03:15 PM   #3
You also have to consider the PPI which stands for pores per inch.
A foam with 10PPI will offer very little restriction to air flow whereas a 60PPI is sure to restrict the air flow.
This UK supplier invites you to 'Get in Touch': Reticulated Foam Supplier, Converter & Manufactuer | RGH Rubber
Old 17th December 2020, 04:28 PM   #4
Banned
Thanks for looking, where was that, I'm not in a hurry? An inch would be fine, I don't want it too thick.
Old 17th December 2020, 04:36 PM   #5
Forget my first find! It was 255 for a 2" thick, 1500 x 2000mm, sheet!
Old 17th December 2020, 04:47 PM   #6
Banned
Lordy
Old 17th December 2020, 04:52 PM   #7
"Intec Foams manage both large and small enquiries, we are here to help."
PU Foam : Polyether and Polyester PU Foam
This UK supplier offers reticulated PU foams in various PPIs, but do they do white?
Old 17th December 2020, 04:59 PM   #8
Banned
Thanks, there's white in the picture
Old 17th December 2020, 05:02 PM   #9
I found this set of PPI images, said to be approximately full scale.
Old 17th December 2020, 05:11 PM   #10
Banned
I wanted something self supporting but it may be simpler and cheaper to use cloth on a frame, thanks for looking anyway and the info.
Reticulated Foam Speaker GrillHide this!Advertise here!
Thread Tools
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
Using reticulated foam with waveguide loaded soft dome tweeters Westy37 Multi-Way 12 4th October 2011 03:14 AM
Grill FOAM -- JBL L100 etc. jmar Subwoofers 3 26th September 2009 03:27 PM
Speaker grill/cover and grill fastener questions. marchel Multi-Way 4 22nd January 2008 01:41 PM
Acoustical foam grill cloth? woody Multi-Way 0 13th January 2003 12:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
