Construction Tips Construction techniques and tips
Wiring Jensen JT 44K DX
Old 17th October 2020, 02:23 AM   #1
Beep23 is offline Beep23
Default Wiring Jensen JT 44K DX
Hello If anyone can help me wire this MC SUT. Im trying to use it with a Denon 103r 14 Ohm to a Hagerman trumpet. Im trying to load it at 470 ohms.
The part that I'm confused about is the resistors that are recommended to reduce ringing. Somewhere I read that they are not needed unless I'm trying to reduce load
I know the recommended load is 100 Ohm for cart but i don't want to reduce load unless its necessary so I was planning on listening to it at 427ohm before reducing load. Thank you all for the help
Old 17th October 2020, 02:53 AM   #2
rayma is online now rayma  United States
The secondary is terminated with 47k inside the preamp. The 47k reflects to the primary as 470R.
So leave the primary winding without a load resistor to get 470R loading.
To get below 470R loading, add a primary resistor to ground. For 100R loading, add 127R to ground.
Jensen does recommend an RC damping network across the secondary, depending on the cartridge's
source resistance. See the data sheet.
Old 17th October 2020, 10:34 PM   #3
egellings is offline egellings  United States
I have these and currently use them as shown for the Denon DL301-II with excellent results
  Reply to this post
Wiring Jensen JT 44K DXHide this!Advertise here!
Jensen JT-11P-1 inbox balanced wiring georgeus Analog Line Level 16 29th June 2018 06:25 AM
Jensen JT-11P-1 wiring help tyla Instruments and Amps 3 31st December 2017 12:35 PM
Wiring a line array: altering wiring schemes for matching levels w/woofer dave251 Multi-Way 6 5th February 2014 01:21 AM
Thiele/Small parameters for Jensen G-600 or Jensen P15LL. Marco Gilardetti Multi-Way 5 3rd January 2014 07:21 AM
FS: Jensen JT-11P-1 line transformer WTB/WTT: Jensen JT-DB-E jsmith1 Swap Meet 0 26th August 2011 11:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
