Construction Tips Construction techniques and tips
Two layer versus four layer PCBs
Old 27th June 2020, 12:58 AM   #41
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by MarcelvdG View Post
For the same reason why audio op-amps always have gain-bandwidth products in the megahertz range.
My headphone amps generally sit around 50-200 MHz GBP...
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 27th June 2020, 04:57 AM   #42
MarcelvdG is online now MarcelvdG  Netherlands
Originally Posted by ohdsp View Post
It's not just the components, it's how they interact with the PCB traces and layout in general. Small SMD parts have some funky behaviour at high frequencies (like 4G and WiFi frequencies which are abundant these days) - resistors can become inductive and capacitors have low impedance, it can have unexpected interactions with a circuit when the parts don't work as expected. Assume with something like an audio amp that will result in more output noise - you can get that by placing your mobile next to some equipment.
True, but the same holds for through-hole components. In general, the bigger the component, the lower the frequency at which it doesn't behave as an ideal lumped component anymore.
Old 29th June 2020, 05:09 PM   #43
ohdsp is online now ohdsp
As I said in a previous post, would be interesting to see the difference by measuring comparable amplifier designs. 2 layer vs 4 layer (with ground plane), SMD vs through hole.
I've not seen through hole resistor designs in an EMC chamber, I have seen SMD parts. Given the larger size of through hole parts I would be interested to see if they are affected in the 2GHz+ region the same way SMD parts are. Given the abundance of that type of interference around now, it must have an impact on noise in some way. Maybe it's at such low level you would never notice it.
Check out the Open Hardware DSP Platform:
http://www.ohdsp.org - http://github.com/ohdsp
Old 29th June 2020, 05:15 PM   #44
rayma is offline rayma  United States
At GHz frequencies, everything matters.
Old 29th June 2020, 05:53 PM   #45
But, when looking at something like an audio application where it is an output signal you listen to, to what level and extent, and how is it affect by something simple like a ground plane and 2 layer vs 4 layer.
Unlikely to be a simple answer, and a power amplifier running off +/-50V will likely differ from something like my DSP boards with analogue stages working at <1Vrms with lots of digital signals.
If you have something like an audio power amplifier with limit bandwidth (say 100khz), then I thought the noise it picks up can "fold down" into it's working range, as it can't do anything else with it, so more output noise? Would it benefit from a 4 layer ground plane on the input sections, what is the real difference from through hole to SMD...
Old 29th June 2020, 06:22 PM   #46
Yes, IMD, rectification, etc. These implementation differences are easily measurable with the proper tools.
The amplifier can have wider bandwidth but use input/output filters, which only addresses some problems.
https://www.edn.com/connect-signals-...nimize-errors/
Old 29th June 2020, 08:55 PM   #47
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
... interesting to see the difference by measuring comparable amplifier designs. 2 layer vs 4 layer (with ground plane), SMD vs through hole.
Please feel free to perform the experiment and report the results! Lay out two PCBs from the same amplifier schematic; build them out into identical chassis with identical power supplies, and then measure their performance. I'm sure that (a) you'd have a lot of fun; (b) other diyAudio members would be delighted to peruse your data.
Old 29th June 2020, 09:30 PM   #48
I'm busy washing my hair....
and building other stuff.
Maybe one day, choose something simple like ESP P3A design, should have SMD and through hole versions of devices that would work, could probably do all 4 layouts on one PCB for testing
Old 29th June 2020, 10:02 PM   #49
diyAudio Donor
It may never happen if you don't do it.
Old 29th June 2020, 10:51 PM   #50
tomchr's Avatar
Sure. Have a look at page 12 here: https://www.ti.com/lit/an/snoa497b/snoa497b.pdf
If those changes made less RF energy reach the inputs of the opamp, definitely.
In case of the EMI-hardened opamps from National (now TI), the benefit is from a filter on die.
Tom
Two layer versus four layer PCBsHide this!Advertise here!
2,4,8 layer coils Hayden Subwoofers 4 5th September 2019 07:48 AM
2-layer vs 4-layer voice coil StigErik Multi-Way 21 2nd July 2013 07:03 PM
Dual layer PCB with second layer being only ground Th3 uN1Qu3 Class D 16 6th February 2011 10:32 PM
midbass - 3" 2 layer or 2" 4 layer? jayam000 Multi-Way 2 20th December 2009 10:53 AM
Constrained layer damping / thin metal / fibreglass layer RobWells Multi-Way 3 6th August 2007 05:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
