Construction Tips Construction techniques and tips
PCB Designs to Study
Old 22nd May 2020, 02:56 AM   #51
mhenschel is online now mhenschel  Canada
Wands out!
Old 23rd May 2020, 01:17 PM   #52
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Expecto PCboardum!
Tubelab, I blow stuff up so that you don't have to.
Old Yesterday, 07:49 AM   #53
hpro is offline hpro  Switzerland
Default Because is has influence on the Circuit
Originally Posted by Indiglo View Post
Why would a PCB need to have style or creativity? PCB layouts need to be functional to meet various engineering design criteria.
Because for certain PCB in Audio its very important that you select the way of Layout very well.
I have to redesign a PCB for a Class A the third time because of Capacitive Problems where the layout of two lines do falsify the output of the input Signal, creating Noise and generating not recoverable Errors like Hum, Noise, Oscillation, all stuff no one wants.
Make short, and where ever it's possible thin lines except when there is a lot of power passing through. If you need to draw long lines - over 10 cm in lengt to make them at least 2mm wide, and if these are Signal lines, stay away from lines which powers up the Board. because of inductive and capacitive noise generation which will occur on the board.
Make if possible a double Layer, if you can't do by yourself then let some shop do it for you. Use a top ground Plane if possible.
I make my double layer by myself. If you need help on that I have wrote some documentation on this some years ago. Can be uploaded here..
The most important thing is, work exactly and clean. If you use Positive Photo reactive PCB from Bangard or any manufacturer, be sure to read their instruction. DO NOT USE TRANSPARENT FILM when you print the LAYOUT with a LASER PRINTER.. I assure you, there will be a lot of Testing and wasted PCB's.
Use Transparent Drawing Paper this will work very well. Make sure that you put the PRINTED SIDE FACE DOWN on the PCB to Avoid Ghost images. After you printed the Layout, check the print if its really DARK BLACK . If you find parts of the print where you think that it needs to be better either print a second sheet and put it over the first one - or manually correct it using Black No Water soluble drawing Pen. Make sure that the PCB side is correct before you print Negative Positive..it's not the same if you look a the PCB "through the PCB" at the lines or if you Flip it.. and look it from Bottom.
May there is need of inverted Printing for double sided PCB. Otherwise when the PCB is finished you will not be able to place the parts as you wish if layout on the PCB is the wrong way around..
Check development Times of the developer you will use.
Check Water temp and amount of developer used with a Scale, which is accurate to at least 1Gramm/Kilo or better.
If you use ACID to Edge the lines, like Ferro3 or similar, make sure that you stand by there while its etching. Use Warm Water of about 50Degrees Celsius, this will speed up the edging and also give better results..From time to time shake the container with the acid that some Air gets into it, this will sure help to reduce etching time.
Documentation you can find on the internet if you want to know more than this or have any other question., all you need to do is to ask.
Hope this helps
Regards Chris
http://www.hecco.ch/pcb_double_sided.pdf
PCB Designs to StudyHide this!Advertise here!
PA designs to study which use DC CF for output stage grid drive mashaffer Tubes / Valves 14 20th January 2019 10:03 PM
New Amp on Study turnA_zpoint Solid State 0 7th March 2016 10:30 PM
Benefits of esoteric designs over traditional designs? ReDress Subwoofers 25 2nd June 2015 11:09 PM
I want to study NoBit Digital Source 3 12th January 2008 02:35 PM
starting to study amp designs Clipped Solid State 27 19th April 2007 07:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
