Construction Tips Construction techniques and tips
Cool trick from de-soldering.
Old Today, 10:36 AM   #21
warrjon is offline warrjon  Australia
I use a Goot solder sucker with the largest tip on the iron I can fit in the area and iron on full blast, makes desoldering quick. I prefer the Goot over the Metcal rework station.
Solder gets stuck in the hole because the joint is too cold and the solder is not liquid, ground planes are the hardest to desolder. A large tip a hot iron and speed means less heat soak into the PCB. A small tip and heat applied too long can have pads lifting from the PCB.
SP10, ...... DIY Linear tonearm, ......Stanton 881s with D3000 stylus, .....BHL phono,.........Pass B1,
MODULUS 86 power amps x4,.............Active line level OX,......... bi-amped OB speakers with Mark Audio Alpair 12P
Cool trick from de-soldering.Hide this!Advertise here!
Soldering - bad tip care or soldering iron? NATDBERG Construction Tips 30 9th January 2019 12:57 AM
ridiculously cool repair trick! aptquark Construction Tips 2 10th October 2011 01:21 AM
Diode trick? Giaime Tubes / Valves 18 28th February 2010 07:30 AM
Soldering tips for soldering station BEST PRICE, FREE SHIPPING, 15% discount vtech9815 Vendor's Bazaar 0 27th January 2010 04:40 PM
Q:cheap trick 142 Tomac Multi-Way 0 21st December 2003 07:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
