Construction Tips Construction techniques and tips
Single rail psu 2 rows of caps
Single rail psu 2 rows of caps Please consider donating to help us continue to serve you.
Old 17th March 2020, 10:22 PM   #1
jimk04 is online now jimk04  United Kingdom
Default Single rail psu 2 rows of caps
Probably too late to ask seeing as I've spent some time today building this!
I have soldered up the cap bank for a 51Vdc supply for a tpa3255. Used 14 of 2200uF caps and for packaging purposes I have 2 rows of caps.
These are all aligned ground inwards, so the two inner copper wires are ground. One outer wire will be in from the bridge rectifier and the other outer will be the smoothed supply.
Have I made a potential ground loop with the physical looping of the wire around the caps.?
Old 17th March 2020, 10:40 PM   #2
rayma is offline rayma  United States
Yes, if you connect both ends of that wire. Better to have the outside wires separate,
and the two inner wires connected together (at the output).
You can cut that loop and reverse the two rows. Then you can join the inner rows and
attach an output lead to the join. This will be electrically the same as before.
Old 17th March 2020, 10:42 PM   #3
Ah....so just leave one end of the ground wire unterminated ?
Old 17th March 2020, 10:44 PM   #4
ubergeeknz is offline ubergeeknz  New Zealand
Put rectifier at one end, load at the other. Provided the rectifier/transformer secondary is not otherwise grounded you will be fine.
Old 17th March 2020, 10:53 PM   #5
That would "work" but post #2 would be better. Alternatively, just use two electrically separate rows
(cut off the U at the far end), making the parallel connections at the rectifier block.
Old 17th March 2020, 11:27 PM   #6
Something like this, where the rectifier and load do not share a path to the caps.
The circuit ground should be taken from the junction of the (-) of the two cap rows.
Old 18th March 2020, 04:29 AM   #7
AllenB is offline AllenB  Australia
AllenB's Avatar
Without cutting, you could do that. Just tie in at the 'fold'.
Old 18th March 2020, 07:14 AM   #8
Thanks for all the replies guys.
Stay healthy
Old 18th March 2020, 01:45 PM   #9
Default Better?!
I thought it all made perfect sense until I came to actually do it so I'm not sure I'm 100% there yet.
So assuming the pictures has the rectifier in from the left....load out to the right.
Positive rail 'loop' is removed from the output end.
Ground is still looped at right end and output connection tapped off the loop.
Maybe do I cut the loop at the input end?
Rectifier end positive feeds both Positve 'tracks'.
Am I heading in the right direction?
I still have
Old 18th March 2020, 05:16 PM   #10
Vovk Z is offline Vovk Z  Ukraine
I think it (first pic) was ok - just use one pair as input and other pair as output.
"One outer wire will be in from the bridge rectifier and the other outer will be the smoothed supply." thats definitely fine, as it should be. Don't connect inner grounds together.
Single rail psu 2 rows of capsHide this!Advertise here!
Single rail power from dual rail SMPS brian92fs Power Supplies 20 12th December 2017 08:27 AM
Adding single rail amp to split rail amp power supply jdelange Power Supplies 2 1st August 2016 08:46 AM
psu setup single rail, dual rail confusion.. trean27 Power Supplies 1 6th November 2014 09:14 AM
Dual rail secondary to single rail maouna Power Supplies 2 26th October 2013 09:05 PM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
