Construction Tips Construction techniques and tips
strip very fine wire, is there a trick?
Old 20th February 2020, 10:24 AM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
is that 0.3mm , or 0.03mm Dia?
if 0.3 , then OK , even mechanical (rotating) tools are good for that ( aliexp. etc) but if 0.03 ...... I'm helpless
in Yore , wire put on Aspirine tab and heated worked , but with nowadays insulation , dunno
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th February 2020, 10:46 AM   #22
myleftear is offline myleftear  Switzerland
myleftear's Avatar
Well it actually is 0.03 mm
0.3 isn‘t really a problem.
Before buying more tools, I tried heating up the insulation (luckily it isn‘t ptfe). Need a magnifying glass to control all is off...
dobedobedo...
Old 20th February 2020, 08:06 PM   #23
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
I've had a lot of luck with sort of sideways pulling on traditional strippers, too. I admit it's challenging, and you always need extra because the piece you're trying to use has a high rate of being rejected from it going wrong. Melting seems legit but gross. Solder pot?
Old 20th February 2020, 08:32 PM   #24
edbarx is offline edbarx  Malta
You can also use a very fine folded sandpaper. I usually use a match to burn the enamel if it is a tranformer winding wire.
Thanks for helping me design my first amplifier.
Old 20th February 2020, 11:05 PM   #25
fredbloggstwo is offline fredbloggstwo  United Kingdom
If you can get hold of a wire-wrapping tool, or sometimes a roll of wire for wire wrapping, they come with an insulation stripping tool built in.
Mike
strip very fine wire, is there a trick?Hide this!Advertise here!
technique or tool to strip 32 awg internal tonearm wire wct Analogue Source 4 1st March 2016 05:52 PM
Diode trick? Giaime Tubes / Valves 18 28th February 2010 08:30 AM
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 04:29 PM
trick company dabeat The Lounge 0 7th October 2007 12:36 PM
How do I strip 30 guage wire? Xylenz Multi-Way 1 20th December 2002 04:06 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
