Construction Tips Construction techniques and tips
Sheared cartridge bolt in headshell
Sheared cartridge bolt in headshell Please consider donating to help us continue to serve you.
Old 3rd February 2020, 04:02 PM   #31
BigE is offline BigE  Canada
BigE's Avatar
Originally Posted by maxhifi View Post
I've seen both. Steel is more common but you never know
Try a magnet.
Will do that tonight. Thanks!
Old 3rd February 2020, 06:06 PM   #32
BigE's Avatar
Try a magnet.
Old 3rd February 2020, 06:26 PM   #33
rayma is offline rayma  United States
Should be either stainless steel or aluminum, neither is magnetic.
Old 3rd February 2020, 08:02 PM   #34
BigE's Avatar
I thought as much. So, if stainless, alum will work. How could I tell if the alum is working. Will it discolour quickly?
Old 3rd February 2020, 08:48 PM   #35
I haven't ever noticed aluminum cartridge hardware discoloring.
Shure used to supply aluminum screws with their cartridges, and they always looked the same,
even after decades later. Aluminum hardware is much lighter in weight than steel.
Old 6th February 2020, 03:37 PM   #36
Kay Pirinha is online now Kay Pirinha  Germany
Kay Pirinha's Avatar
Here is the other side. It looks like the previous owner was forcing a bolt that was too big.
No, not necessarily. A bolt's/screw's core diameter (i.e. the threaded hole) is always smaller than it's outer dia.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Sheared cartridge bolt in headshellHide this!Advertise here!
Turntable pop, headshell/cartridge grounding HawkeyM Construction Tips 5 15th February 2015 09:52 PM
Headshell and Cartridge b767 Analogue Source 1 6th October 2012 12:20 AM
#8-32 bolt fit in a 4.5mm hole? Sangram Parts 6 16th September 2009 07:35 PM
Withworth bolt for AR3a? KJ2005 Multi-Way 4 9th November 2008 09:51 PM
How To Cut A Nylon Bolt? kelticwizard The Lounge 4 31st May 2008 06:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
