Construction Tips Construction techniques and tips
How much torque is 5N-cm?
How much torque is 5N-cm? Please consider donating to help us continue to serve you.
Old 27th January 2020, 02:53 PM   #1
myleftear is offline myleftear  Switzerland
myleftear's Avatar
Default How much torque is 5N-cm?
Hi!
I just found this quite useful info on properly mounting jfets (or other to-220 / to-247 etc. devices):
https://www.infineon.com/dgdl/Infineon-AN2013_12_Screw_Tightening_Torque-AN-v1.0-en.pdf
The recommendation is 0.6 - 1 Nm.
(hold ~60 - 100gr at 100cm distance, or ~6000 - 10000gr at 1cm distance)
If I understand it correctly, this is quite tight for a M3-thread, but not "as tight as I'd tighten the wheel-bolts of a car"...
dobedobedo...
Old 27th January 2020, 03:12 PM   #2
Mark Tillotson is offline Mark Tillotson
Firstly convert to Nm, 100Ncm = 1Nm, so 5Ncm = 0.05Nm
My rough guide to torques from human arm:
0.1--0.3Nm - finger and thumb twisting
1Nm - whole hand turning screwdriver
10Nm - both hands turning a steering wheel
100Nm - break your arms!
The symbol for the newton is "N", not "n" which means nano.
SI units and multipliers are always case sensitive.
0.6Nm is pretty normal rating for M3 steel-to-steel fastening. Direct into soft aluminium you'd use much less, 0.1Nm perhaps, or risk stripping threads, so it depends if using bolt and nut or bolt and tapped Al heatsink.
Old 27th January 2020, 03:17 PM   #3
myleftear's Avatar
Thank you, Mark.
I corrected the nanometer back to Newtonmeter
dobedobedo...
Old 27th January 2020, 04:19 PM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Excellent data.
Doubly useful because in Audio/Electronic Forums people is concerned into minute details of Electrical units (which is fine of course) but in general ignore mechanical ones, which are also very relevant to DIYers. (which are supposed to roll up their sleeves and get their hands dirty)
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 27th January 2020, 06:42 PM   #5
ubergeeknz is offline ubergeeknz  New Zealand
Torque until it lets go, then back off a quarter turn How much torque is 5N-cm?
Old 27th January 2020, 07:01 PM   #6
kevinahcc20 is offline kevinahcc20  United States
kevinahcc20's Avatar
That converts to 5.3 to 8.8 lb-inch (or inch-lbs in the old days), probably not a critical specification with that wide a range but clearly hand tight with a screwdriver and avoid using your 20V impact gun!
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 27th January 2020, 09:06 PM   #7
myleftear's Avatar
I wasn't sure wether it was just tight or veeery tight.
But, as you say, the range is so wide that it should be ok to go as far as you want it to sound good afterwards (so don't exaggerate, it's not shipyard work...)
My first (ACA, recently) was way too loose, but all went well though
(PS: The experts are explicit: _don't_ use tools like in the image below)
dobedobedo...
Old 28th January 2020, 05:05 AM   #8
PRR is offline PRR  United States
PRR's Avatar
Google usually knows this stuff:
1 Nm to inch pounds - Google Search
How much torque is 5N-cm?Hide this!Advertise here!
Torque Acoustics - T12 julio baiao Instruments and Amps 18 31st December 2019 02:49 PM
torque on silca pads MaccAu Parts 11 23rd January 2018 02:30 PM
Max torque for M4 bolt into 8mm Aluminium triplej Construction Tips 13 18th January 2014 01:28 PM
Torque Bass Amp T100 1EB Need Transistor Trev666 Vendor's Bazaar 2 14th June 2012 02:46 PM
Please Recommend a Torque Screwdriver Seraph Everything Else 12 17th August 2008 01:42 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
