Construction Tips Construction techniques and tips
Making a simple LED music controller?
Making a simple LED music controller? Please consider donating to help us continue to serve you.
Old 13th January 2020, 12:15 AM   #11
Refugee1 is offline Refugee1  United Kingdom
Refugee1's Avatar
The audio should go to the third terminal on the pot.
While you have got the wires off the gate try touching between the tab on the IRF840 and the gate with a wet finger. The LEDs should light up and then dim slowly. 12 volts will not bight you.
You can also drive the gate with a meter on diode test range.
Once the pot is connected correctly the LED will dim quickly.
Old 13th January 2020, 04:23 AM   #12
c4ppucino is offline c4ppucino
Hi, not sure if I follow. If I connect the wires on the pot to the 2 furthermost posts, wouldn't the resistor value be constant (in this case, 50k)? Let's say the terminals are labeled A-B-C, which terminals should I connect the wires and the gate and drain to?
As of now (without changing anything from the picture above):
- when I plug in power, the LED lights up. I can't dim it by adjusting the pot
- when I plug in the audio jack, the LED dims. I can control the brightness a bit by adjusting the pot
- when I set the pot to barely dim light, and I play music, the LED lights up, but stays that way. When I pause the music, the LED stays that way for about 2-3 seconds, then go back dim
I built (soldered) it based on this schematic I found on youtube, with AUX input in place of the mic.
Old 13th January 2020, 04:30 AM   #13
Originally Posted by MAAC0 View Post
Try a 10K pot and find out the resistor ratio needed for making an attenuator pad.
Remove also the Mic Bias resistor. (10K on the left perhaps, It should be connected to the supply).
Hi, thank you for the reply. I tried using a 50k pot, and the LED still blink randomly, even without anything connecting to it but the pot's terminal. Havent tried removing the 10K resistor on the PCB yet. I tried to find the route leading to the power supply, but I just couldn't. I just can't see which goes where on the PCB....
Originally Posted by The Peasant View Post
It's nicer when you have different LEDs responding to different frequencies:
The Electronic Peasant's LED Color Organ Page
Just leave out the first transistor stage.
Take care,
Doug
Hi, thanks for the link, but that one seems too complicated for me. I only know basic stuffs like resistors, PCB, soldering, etc
Old 13th January 2020, 11:07 AM   #14
Refugee1's Avatar
The pot is wired wrong.
You need to use all three terminals.
Making a simple LED music controller?Hide this!Advertise here!
Buffalo iii SE making music! Manolo47 Twisted Pear 3 28th August 2016 05:53 PM
Love making music iUSERTLO72p Music 38 1st January 2008 06:15 AM
Orion's are making music !!!!! sl_1800 Multi-Way 4 18th February 2005 01:25 PM
Any musicians out there making their own music? specialx Everything Else 0 30th September 2002 02:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
