Construction Tips Construction techniques and tips
Which thread insert for a cast enclosure?
Old 7th January 2020, 10:04 AM   #1
amundsen is offline amundsen  Belgium
Question Which thread insert for a cast enclosure?
Hello,
I am currently designing a small speaker to be set on a microphone stand. The enclosure will probably be cast in a special concrete-like material stuffed with some fibres to make it lighter.
I'm not sure how to design the location on the enclosure that will be screwed on the stand. Solutions currently encompassed are:
- a thread insert made to be hammered in wood like this one
- another type of thread insert, maybe better for a cast but I have doubts about the mechanical resistance
- a thread insert with a plate, to be itself screwed into the enclosure (bigger footprint)
- a hole with a shape adapted to a nut (easiest solution for a cast probably)
What do you think?
Old 7th January 2020, 10:19 AM   #2
OlegSh is online now OlegSh
I would simply cast in a flange nut. The nut should be cast in closer to the inner surface of the enclosure where the flange goes inside of the compound. The flange will keep the nut always in the compound and also add more surface so the enclosure does not crack when tight mounting it to the stand.
Oleg
Old 7th January 2020, 10:23 AM   #3
Good idea! I could even find ones with a 3/8 thread for a reasonable price. Thank you OlegSh.
Old 7th January 2020, 10:26 AM   #4
justanalogue is offline justanalogue  Netherlands
I would use this one 219 Thread adapter | Konig & Meyer
Get a plate with 1/2 UNC thread for the inside and cast around that.
Kind regards,
Willem.
Old 7th January 2020, 10:50 AM   #5
Do you mean a plate of the same kind as this one?
Old 7th January 2020, 10:53 AM   #6
No just a piece of metal with an 1/2"UNC thread in it, like a square or round plate.
Old 8th January 2020, 10:19 PM   #7
phase is offline phase  United States
Concrete takes compression forces well, but not other types of loads.
I would tend to sandwich two plates together using bolts, and a rubber gasket on each side against the concrete material.
Cool project it sounds like.
Old 15th January 2020, 08:46 AM   #8
Something like this?
Please tell me if the representation in the attached diagram is correct (sorry, couldn't make it appear directly, don't know why). So, the metal places are sandwiched only. There's no other tie between them and the thread insert?
Thank you!
Old 17th January 2020, 03:36 AM   #9
That’s it.
Cast in pickup points are problematic, tend to spin inside, unless they are huge.
Which thread insert for a cast enclosure?Hide this!Advertise here!
How to Reseat this Insert WntrMute2 Construction Tips 3 5th August 2018 10:52 PM
Headphone Cue Insert Box Havok87 Analog Line Level 0 2nd February 2016 12:43 AM
tubular sub enclosure build thread curtis73 Car Audio 4 23rd September 2014 09:16 PM
Insert a Volume Pot Ciu Chip Amps 0 16th September 2013 11:49 AM
Audio Nirvana Super 12 Cast Frame in Aperiodic Enclosure majerjack Full Range 3 2nd March 2010 10:03 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
