No one has talked about safety more than hearing, breathing and eye protection.
My tip is to always unplug the cord every time you change, adjusting the tension something that is around the router bits makes this a routine, then you do not have to get rid of fingers and other things. The router does not know the difference between flesh or wood.
Never hurry let the machine do its job even if it would take a few minutes more, do not force the router bit against the material hard you will get better results and everything lasts longer.
