Construction Tips Construction techniques and tips
How much clearing for a PCB?
Old 16th November 2019, 10:21 PM   #11
Nocturna81 is offline Nocturna81  Netherlands
Originally Posted by Mark Tillotson View Post
Adding insulation on the inside of the case can be useful if clearance might be iffy - but not gaffa tape(!). I've used kapton tape for this in small diecast boxes.
Isn't that a bit fragile? The kapton tape that is?
And wouldn't the tape start peeling off after some time?
Old 16th November 2019, 10:29 PM   #12
rayma is offline rayma  United States
Yes, instead we use Nomex 410 sheet stock, which is very tough and has a high voltage rating.
It can be cut with good scissors, punched, or die cut. We punch it to clear the spacers and install it
between pcbs and the chassis. No need for adhesives, since it is captive.
Old 18th November 2019, 12:13 PM   #13
fredbloggstwo is offline fredbloggstwo  United Kingdom
I also use FR4 copper-clad board with the copper side down: use plastic spacers between it and the PCB above and between it and the chassis. The copper side can also double up as a ground screen for audio work.
Mike
How much clearing for a PCB?Hide this!Advertise here!
Clearing out DIY speaker builds pjblakey Swap Meet 0 4th July 2013 05:07 PM
Clearing out electronic parts tdowad Swap Meet 0 6th November 2012 05:41 AM
Clearing out a bunch of stuff JZatopa Swap Meet 0 2nd November 2012 10:42 PM
Clearing out exurbia Swap Meet 13 15th February 2011 06:10 AM
Copyright ©1999-2019 diyAudio
