Construction Tips Construction techniques and tips
Power-switch & Volume-control in one?
Old 30th October 2019, 02:18 PM   #11
myleftear is offline myleftear  Switzerland
myleftear's Avatar
Originally Posted by Vovk Z View Post
- they are all battery powered! Don't do that with 110-230 VAC!
Thanks for the advice!
I was thinking of a tricked design: Having the attenuator-knob mechanically switching the power-switch... Or, like, have the Attenuator trigger a relay which switches the mains on/off...
I'm sure you can read out of these that I am no expert... and, I know it's not thought through, but I'm "having visuals". I may try to build something (someday).
da.
Old 30th October 2019, 02:24 PM   #12
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
In the tube TV's and radios, this combined switch and volume control was very usual, and no troubles still in our 220VAC lines.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 30th October 2019, 04:43 PM   #13
Vovk Z is offline Vovk Z  Ukraine
Old tube TV were far from today safety standarts. So they are not a good example
In modern audio-devices, usually it is used a way with auxiliary power supply and low-voltage low-current switch (button), which operates a power relay or semicunductor switch, which turns on main power supply.
Old 30th October 2019, 04:48 PM   #14
Yes, but it generates other problems, like power spent continuously from this stand by circuitry. I prefer the classic switch.
Old 30th October 2019, 09:56 PM   #15
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
You could use the switch on the volume control to activate a relay, with DC. No hum.
Another option, if you go for a stepped attenuator, have an extra deck on it at some distance behind the signal switching decks, possibly with a metal screen in between. Or also here, use the relay trick.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 31st October 2019, 01:04 AM   #16
The Peasant is offline The Peasant  Canada
The Peasant's Avatar
I have built circuits in the past that used a battery to initially turn on the power relay, which was then switched out by one of the relay contacts once the ac power supply came on. This way there is no current draw at all until the power switch is turned on and since the battery supplies only a short pulse of power it lasts a very long time before needing replacement.
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
Old 31st October 2019, 02:00 AM   #17
Here is an example of a circuit to do this.
K1 is a relay with a 9 volt rated coil and needs to have a sufficient contact rating for powering all of the desired power supplies. The LM311 comparator senses the power switch position and activates the relay using the 9 volt battery. The 100uF capacitor across the relay coil holds it on until the AC powered 9 volt power supply can take over. The 9 volt power supply actually supplies about 11 volts, ensuring that it powers the relay and circuit instead of the battery. I have had the batteries in these power supplies last many years before requiring replacement.
Take care,
Doug
Power-switch & Volume-control in one?Hide this!Advertise here!
LP volume control + source switch fernfrost Construction Tips 0 11th February 2016 12:17 PM
A DIY audio switch with volume control for PC robikz Construction Tips 5 2nd April 2015 05:48 PM
RELAY SWITCH VOLUME CONTROL - HELP NEEDED ! vmed_cha_gr Pass Labs 7 7th April 2012 01:18 AM
Switch & Volume control needed... martinschki Pass Labs 0 3rd October 2010 12:30 PM
Needs E-Caps or volume control switch? 65blkbkgt Car Audio 5 25th August 2007 06:21 AM
Copyright ©1999-2019 diyAudio
