Construction Tips Construction techniques and tips
Perforated Chassis Question
Old 14th September 2019, 12:28 AM   #11
gabdx is offline gabdx  Canada
Aluminum will catch up microwaves, however with more broadband frequency I think steel will catch and shield a lot more, i have to research if aluminum is a good antenna to shield AM and FM radio...
In any case the holes will not hinder the metal ability to shield the interior from some electromagnetism.
A real shield has two layers, you still need to measure each path to ground and be the same length to null the parasitics effect in the power supply...
You should be good
grid stoppers of proper values prevent the Mhz from being amplified , so use them everywhere, they don't lower your sound quality
amplificateurslegrand.ca
Old 16th September 2019, 11:06 AM   #12
DF96 is offline DF96  England
Aluminium with small holes will block RF up to the frequency where the holes are a few percent of wavelength. At very low frequencies you need the aluminium to be at least a few skin depths in thickness.
Old 16th September 2019, 11:07 AM   #13
WntrMute2 is offline WntrMute2  United States
WntrMute2's Avatar
All your responses were helpful. I went with perforated bottom panels.
Perforated Chassis QuestionHide this!Advertise here!
Perforated baffle behind driver phase Full Range 0 3rd January 2016 04:58 PM
Cutting my own perforated panels joojoo1234 Planars & Exotics 6 28th November 2011 07:34 PM
Perforated Grill dallas Multi-Way 4 12th May 2009 07:10 PM
What dimensions for perforated AL sheet? CarlyBoy Tubes / Valves 2 26th December 2007 11:21 PM
degreasing perforated aluminum wrl Everything Else 26 30th July 2003 07:19 AM
Copyright ©1999-2019 diyAudio
