Construction Tips Construction techniques and tips
How to change over to LED lights.
Old 30th August 2019, 09:38 AM   #31
redrooster is offline redrooster  Australia
redrooster's Avatar
Finally got it done and it looks great! It won't look as good on a photo for some reason? But I'm happy with it all the same.
Old 30th August 2019, 09:42 AM   #32
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by redrooster View Post
That green dial is a good look and adds to the vintage style too.
The original bulbs were painted in green, too. They were 12 V 0.1 A, not unobtainium, but I hadn't them handy. So I decided to opt for LED's instead.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 30th August 2019, 09:44 AM   #33
Do you plan to illuminate the dial in blue also? Would fit perfectly, imho!
Best regards!
Old 30th August 2019, 10:35 AM   #34
redrooster's Avatar
Best regards!
The dial is illuminated with two blue LEDs it just doesn't show up in the photo?
Old 30th August 2019, 10:52 AM   #35
abanico is offline abanico  Spain
Little incandescent bulbs with two wires coming out the glass are easily available . They are perfect to run in series and you can choose between 6,12,or 24v . Once in series they last for ever and are the perfect match for an old gear . I use 2,12v , to run on the 6v ac and the light is enough and current draw very low . The light is so warm and pleasing to look at !
When i use leds to make a little lens i use a metacrylate screw with the end polished to get a more diffused light as leds are always blessing in the dark.
Old 30th August 2019, 11:56 AM   #36
Mooly's Avatar
Excellent
Old 1st September 2019, 01:30 AM   #37
phase is online now phase  United States
Glad you got it working.
I would be looking at an available constant current driver circuit for these, and bag the resistors if I were going about it.
Old 6th September 2019, 08:34 AM   #38
russc is offline russc  England
Resistors $1 a bag and very simple to implement.
LED driver more costly and if driving LEDs in parallel you run into current sharing problems.
How to change over to LED lights.Hide this!Advertise here!
And about lights? zedda PA Systems 9 24th June 2016 10:44 PM
Lights agabriel Parts 6 25th February 2016 06:59 AM
lights Kitax Chip Amps 18 4th October 2012 06:16 PM
If I change B+ do I have to change the circuit? nige838 Tubes / Valves 3 18th August 2011 11:16 AM
Copyright ©1999-2019 diyAudio
