Transistor thermo coupling
Hi..
I was pairring transistors today, and they needed to be coupled thermally, so I looked for shrinking tube, after lots of searching I realized I've used it up, what to do?, on the table I noticed a fuse holder, and figured that I could use the clamps around the two transistors, broke of the plastic, bended the metal a little, now I have a small fancy clamp, that always will keep a good pressure, I have loads of old fuse holders, and bet you do too, my little trick,
