Construction Tips Construction techniques and tips
Need soldering help
Need soldering help
Old 31st March 2019, 05:11 PM   #1
woody is offline woody
Default Need soldering help
I have started building a Zen9 but have hit a little problem . This amp uses the the LD1014D that is in a To251 package is there an EASY way to solder leads to those little pins as I see some constructors of this amp have done ?
Old 31st March 2019, 05:51 PM   #2
rayma is offline rayma  United States
Strip the wire to about half the pin's length. Tin both the lead and the wire
to make the soldering quicker and easier. Clamp both in a jig so there's no
relative motion, with the wire touching the lead in the proper position
(parallel to it, on top). Solder the wire to the pin.
https://www.amazon.com/ProsKit-900-0...48222610&psc=1
Old 31st March 2019, 11:39 PM   #3
Thanks for the tip. After looking at that device I went ahead and ordered it.
Old 31st March 2019, 11:48 PM   #4
You'll still need steady hands to do the soldering. I'd also recommend
63/37 rosin core solder, which works much better than 60/40 solder.
Around 20 gauge is good for most through hole work.
Need soldering helpHide this!Advertise here!
Soldering - bad tip care or soldering iron? NATDBERG Construction Tips 30 9th January 2019 12:57 AM
Soldering tips for soldering station BEST PRICE, FREE SHIPPING, 15% discount vtech9815 Vendor's Bazaar 0 27th January 2010 04:40 PM
Just got a soldering kit... keantoken Everything Else 4 1st November 2006 03:08 AM
more soldering help please theChris Equipment & Tools 22 5th June 2003 04:07 PM
On Soldering vpharris Equipment & Tools 9 23rd April 2003 06:14 PM
Copyright ©1999-2019 diyAudio
