Construction Tips Construction techniques and tips
insulated speaker cables
Old 18th March 2019, 09:41 PM   #11
Hextejas is offline Hextejas
Originally Posted by Speedskater View Post
Are the loudspeaker, powered speakers?
Do you have a powered sub-woofer?
Loudspeakers not powered.
Sub woofer is powered.
Old 19th March 2019, 09:56 PM   #12
Well, I found a big part of it I think. I noticed that one of the RCA input connections was kinda loose so I started to tighten it when I also saw that the ground side of it was not making contact with the chassis.
After I fixed that it improved the 60Hz hum considerably.
I am so thankful to this site that I am going to give a donation in recognition of all the help that I got here.
Thanks again.
Old 20th March 2019, 02:37 PM   #13
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
That's good news, grounding seems to have been the issue, very unlikely to be anything to do with the speaker cables
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 2nd April 2019, 12:20 AM   #14
jlinkels is offline jlinkels  Netherlands Antilles
If these are passive speaker, the chances of picking up hum are zero. Especially if you cross power lines. Impedance is way to low to pick up anything at 50/60 Hz.
You did not answer whether this is an active speaker.
Old 2nd April 2019, 03:48 AM   #15
Default I got it fixed
And as you all suggested it had nothing to do with the cables. I had done a poor job of routing the cables within the chassis. After I got that sorted out, the hum as well as other extraneous noises have disappeared.
insulated speaker cablesHide this!Advertise here!
Gotham interconnect cables, speaker cables and coaxial cable Musik007 Twin Audio 24 23rd August 2013 04:57 PM
Teflon insulated speaker cable dazed Parts 12 30th December 2010 12:01 PM
Long Stem Inexpensive Insulated Speaker Binding Posts DreadPirate Parts 0 21st January 2010 11:14 PM
DIY speakers cables with several non-insulated cores pk Multi-Way 5 15th April 2005 08:27 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright ©1999-2019 diyAudio
