Construction Tips Construction techniques and tips
Safe to replace these wires (internal amplifier wiring)?
Old 17th January 2019, 04:48 PM   #1
ThatDavid is offline ThatDavid
Default Safe to replace these wires (internal amplifier wiring)?
currently in the process of renovating a HK6500, i have disassembled it as much as it would go and i noticed the internal wiring for both power and audio signal is done using these kinda wires (pic). They are plastic insulated, solid core with what seems like tin jacket. I am not sure on the core, it's gray and bendy, so probably aluminium.
I cut some of them off thinking they were normal stranded wiring that i can resolder together afterwards but i doubt ill be able to join them together.
They are AWG18, would it be a good idea to replace them with stranded copper wiring? For the sake of lower impedance and resistance as well as QoL when putting the amp together (these ones are super stiff and the insulation seems to be severely heat degraded).
What would you guys recommend?
Thanks!
Old 17th January 2019, 06:31 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
If they are severely heat degraded I would book to replace with PTFE or silicone covered wire.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th January 2019, 06:58 PM   #3
They are degraded in a way where the plastic is really stiff and shows light cracks in tight bends.
So i guess PET or silicone wire would be better, though i can't find the appropriate colors (the internal wiring is differentiated with colors like BLK, RED and GRN)
Old 17th January 2019, 09:50 PM   #4
PRR is offline PRR  United States
PRR's Avatar
Audio wiring is almost invariably tinned copper. Not Aluminum. Tinned copper is of course silvery color, but solders easy with mild flux.
I can't tell if your sample is single-core or a shielded cable. Shield cable sometimes has aluminized mylar wrap. You don't try to solder to that, there is a drain wire (again usually tinned copper) which is your connection.
Old 18th January 2019, 08:45 AM   #5
Hmm
Ill test it with dilluted nitric acid and see if it turns blue/green.
Old 18th January 2019, 01:16 PM   #6
So seems like tinned copper indeed. I used my microscope and there is a bit of coppery color in the center. There is no mylar wrap though. It's just solid piece of tin with tinned copper in the center. Never seen such a wire before, but i guess the impedance shouldnt be too bad if it's copper after all.
Safe to replace these wires (internal amplifier wiring)?Hide this!Advertise here!
Internal chip amp wires Dominick22 Chip Amps 20 8th February 2006 02:34 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
SL Phoenix or other dipole owners +internal wires rick57 Multi-Way 4 18th February 2005 12:32 PM
Pearl - internal wires and grounding question Boban Pass Labs 3 2nd March 2003 03:03 PM
Copyright ©1999-2019 diyAudio
