Construction Tips Construction techniques and tips
Chassis ground
Chassis ground
Old 15th October 2018, 09:57 AM   #21
DF96 is offline DF96  England
Yes. If the signal ground is not connected properly to the safety ground then there is no safety connection for the signal circuits. This is fine, if you build with double insulation standards in mind or avoid touching any external connections while the equipment is powered on. A resistor may reduce hum, but does nothing for safety.
Chassis groundHide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Voltage between chassis ground and earth ground haselphlunk Instruments and Amps 17 19th November 2012 04:21 AM
TT signal ground v. chassis ground and hummmmmmm texaslonghorn Analogue Source 0 25th November 2009 02:30 AM
chassis ground vs. earth ground avid Chip Amps 4 10th November 2006 12:56 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
