I'm looking for a way to connect 3-way speakers to their respective amps. Each driver has its own amp so that totals 6 wires that I have to run from the amplifier box to each speraker.
I'm tempted to use DIN connectors since they're pretty cheap and easy to get. The maximum power per driver is 40W, so could those handle it?
The other alternative I can think of is Molex connectors, but for a 4-pin connector I would have to use a common ground wire.
I use these exclusively...well made and reliable. They make fool-proof connections inevitable.
speakON / HPC Speaker Connectors in the Connectors & Adapters Department at Parts Express | 1510
Mike
Mike
