Construction Tips Construction techniques and tips
Make small acrylic? window in fascia to be lit by LED
Old 7th December 2018, 02:04 AM   #11
sunside is offline sunside
Hi,Sthcoaster. The clear acrylic sheet is usually used to be made into led backlight panel or acrylic lighting panels. It can be cut into any sizes and shapes with the laser machine. The saw is also can be used to cut it. According to my experience, it is difficult to melt & pour the acrylic sheet. If you need the clear material and backlight it, may be you can try the clear glass cement. It is easy to buy and use it.
Old 7th December 2018, 03:23 AM   #12
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by sthcoaster View Post
There will not be any other acrylic on the fascia - no acrylic panel to mask and backlight etc. just some smallish holes/carving in the wood which I want to fill with a transparent material which will be backlit and these will be flush with the surface of the wood
What you need is a light pipe. They're available commercially (Digiey, et al.) They're often used with SMD LEDs. A piece of acrylic rod would do the same job. I bet it'd look really nice if you polished the end of the rod.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Make small acrylic? window in fascia to be lit by LEDHide this!Advertise here!
Adcom GFA-545 Distortion LED Lit -w/schematic PreCD Solid State 3 8th November 2013 01:24 PM
Led lit surround shelving Daem Construction Tips 12 29th July 2013 11:54 PM
Rockford Fosgate BD1000, green led & protect led lit. djmdp Car Audio 5 10th October 2012 05:57 PM
GFA 535 II thermal protection led lit kheper Solid State 1 23rd June 2009 05:01 AM
searching for needle vu-meter, led back lit cbriere Parts 13 4th September 2007 06:13 PM
