Construction Tips Construction techniques and tips
Cleaning silver plated connector pins from Ag2S?
Old 28th January 2017, 01:06 PM   #1
50AE is offline 50AE  Bulgaria
Default Cleaning silver plated connector pins from Ag2S?
Is there a solution that can clean in a easy way, I mean, to dissolve the silver sulfide without the need of mechanical intervention? I have some Russian military screw power connectors that are Ag plated, but tarnished and will be hard to be mechanically cleaned.
Thanks!
Old 28th January 2017, 01:33 PM   #2
DUG is offline DUG  Canada
Try this:
17 Apart: How To: Polish Silver in a Baking Soda & Salt Bath
I think each piece needs to touch the aluminum.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 28th January 2017, 01:37 PM   #3
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I use a fibre glass pen.
| Fibreglass Bristle PCB Cleaning Brush, 4mm diameter |
http://www.ebay.co.uk/itm/like/28117...8208994&crdt=0
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Last edited by JonSnell Electronic; 28th January 2017 at 01:39 PM. Reason: More choice of suppliers.
Old 28th January 2017, 01:40 PM   #4
This works very good, but each pin, as you said, must touch the foil. Too bothersome if you have to clean a large batch.
Hey, thanks! It looks like an excellent tool! I'll buy one and give it a try.
Old 29th January 2017, 07:50 PM   #5
fredbloggstwo is offline fredbloggstwo  United Kingdom
The best way I have found of cleaning silver contacts is to use Silver dip (Silvo), providing, that is, that you have the item free to dip.
Dip it for about 20 to 30 seconds using a piece of strings to hold it in the liquid and then rinse in cold water and blow dry.
Its perfect for the pins inside XLRs that you can't get to and it doesn't remove the silver plating, just the tarnishing.
I just used it today on some chassis mounting BNC connectors - they came up a treat.
Mike
Old 29th January 2017, 07:58 PM   #6
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I think the same stuff in the US of A might be Tarn-X. It uses thiourea as its active ingredient.
Old 31st January 2017, 04:45 PM   #7
Yes you are right, I just checked the label. Main ingredient is 'acidifier thiourea' Whatever that may be.
Mike
Old 2nd February 2017, 12:18 PM   #8
lcsaszar is offline lcsaszar  Hungary
My understanding is that silver-oxyde is conductive. And a plug-and-socket connector is self-cleaning.
Old 8th February 2017, 03:35 AM   #9
BillWojo is offline BillWojo  United States
That's my understanding also, silver oxide was conductive and not to worry about the tarnish on it.
BillWojo
Old 8th February 2017, 03:59 AM   #10
wrenchone's Avatar
This may be true, but you're much more likely to encounter silver sulfide than silver oxide. Reactivities are different.
Cleaning silver plated connector pins from Ag2S?Hide this!Advertise here!
7732 Raytheon Vacuum Tubes 6CB6 Equivalent Low Noise Gold Plated Pins tomlang Swap Meet 1 19th August 2018 06:32 PM
silver plated wire jernejx Parts 0 8th January 2015 02:14 PM
Help cleaning tube pins astouffer Tubes / Valves 10 11th December 2007 07:51 AM
Connector, where can I get pins for it? AdamB Parts 6 14th March 2006 03:13 PM
Cleaning oxidised tube pins. JoeBob Tubes / Valves 18 21st August 2002 03:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
