Construction Tips Construction techniques and tips
Danish oil plus a clear?
Old 13th May 2016, 06:46 PM   #1
SS4927 is offline SS4927  Canada
SS4927's Avatar
Default Danish oil plus a clear?
I tested this Danish oil and quite like the looks of it. Now I have two questions,
For (possibly) better results would you advise using some type of pore opener prior to applying Danish oil, or would it not be recommended?
And, How about an oil based clear over the oil after it has time to set up? With or without the furniture I seen had a stunning finish. I think I remember the fella mentioning that it also had some satin clear over the Danish oil. What are your thoughts?
Finish pictures existing of Danish oils would be great, too
Old 16th May 2016, 01:19 AM   #2
chrisb is offline chrisb  Canada
I'd leave the pores as they are; as for finish clear coat over the fully cured oil finish, while I personally like the speed of application of sprayed NC lacquer (not water based urethanes), in keeping with the oil finish, how about finishing paste wax. I've used both a Watco product -Satin Wax, and Minwax brand paste wax. The former is as easy to apply as the oil finish itself, and whenever possible, I like to use product from the same manufacturer to ensure chemical compatibility.
Of course, all oil/ wax finishes eventually need maintenance - the lacquer doesn't, unless damaged by the usual culprits
We’re just a bunch of monkeys on a big blue spinning ball - Don Caron
Old 16th May 2016, 12:36 PM   #3
Fivetide is offline Fivetide  United Kingdom
Fivetide's Avatar
Depends on the material. hard woods it works fine as is. Then I buff it with a good bee's wax. Straight onto a Birch pine etc, I wouldn't know never tried it (yet) but a good 50/50 shellac perhaps would stop the blotches.
The only thing I 've tried on Birch ply is Chestnut acrylic sanding sealer followed by Chestnut Acrylic Lacquer - no pics sorry.. it simply looks like its been varnished without turning yellow..
Old 16th May 2016, 12:38 PM   #4
R.I.P.
I have only gone as far as three coats of Danish Oil so never done a glossy version.
I have seen a five coat application and it was glossy.
Danish Oil is very easy to repair. Just rub it down and apply more oil.
regards Andrew T.
Old 16th May 2016, 01:00 PM   #5
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
I would use paste wax after the Danish oil. If you want to build up a surface layer I have had good results with waterlox. https://www.waterlox.com/
Thin it with mineral spirits and wipe on thin coats. it can build up to a very nice shine. Also very durable.
Be careful with any of these oil finishes..... Rags can and will self combust.
http://www.evancotler.com
Old 16th May 2016, 01:02 PM   #6
Fivetide's Avatar
This is Danish oil on European Walnut Heart without a polishing I guess a veneer would look similar.
Danish oil plus a clear?-img_0439-jpg
Old 16th May 2016, 11:08 PM   #7
paul burchell is offline paul burchell  Canada
paul burchell's Avatar
What type of wood are you planing to finish.
Melting some bees wax into linseed or tung oil to create a cream consistent to soft butter can be used in the final polish.
Old 29th May 2016, 08:39 PM   #8
SS4927's Avatar
A few are exotics and have beautiful looking colour and grain. Plus a few north american species, maple, cherry, and a couple different oak, I might of left out a couple.
Anyhow after getting some of it ripped down and witnessing the colours in its natural raw state I might not want to tangle with it much in way of staining, question mark. Then some of it like the rich grain oak, takes to colour stains exceptionally and shows well. It will be multi coloured, wich I like. Maybe Ill stain some boards while just clearing others.
I tried to capture what Im talking about will set a trial picture once upload finishes. Although the lighting is p*$$ poor Ill give it a try.
Old 29th May 2016, 09:22 PM   #9
SS4927's Avatar
Edit time expired, oops.
Some arent included in pictures I have enough cut to get started.
As you can see I burned a couple 1/8 pieces, oops again. Its not badly burned nothing the sanding phase shouldnt take care of.
Fivetide I really like the carving, very nice proudly hang that one up for display.
Old 29th May 2016, 09:36 PM   #10
SS4927's Avatar
Im thinking now, of different product that leaves it mostly natural looking yet highlights whats already there but doesnt take away from it "natural" look.
I think I will stain some and leave some light actuallu, for the contrasting effect. But I could use some more help there, what type of products are best for this?
Danish oil plus a clear?Hide this!Advertise here!
Danish 2 way speakers SirByrd Multi-Way 15 16th September 2012 12:15 AM
Oil in Paper in oil capacitor. ashok Parts 18 19th July 2004 07:10 PM
Danish Physics Point Zero 2 mpopovics Multi-Way 0 4th December 2003 03:41 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
