Construction Tips Construction techniques and tips
Woodware
Woodware
Old 30th April 2015, 05:04 AM   #1
rpi is offline rpi  United States
Default Woodware
The wooden case for Raspberry Pi Radio. Created from 1/4" cherry and walnut boards. Sawed on scroll saw, glued together, sanded on spindle sander and manually. It still needs the finish to be applied. The front and back panels have been made of black acrylic glass on a scroll saw as well.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
I call it woodware in the same vein as hardware and software because sometimes it needs even more time and effort to complete.
Old 30th April 2015, 02:57 PM   #2
guangui is offline guangui  Puerto Rico
Very nice and beautiful! How it sounds? How did you cut the small square holes? A pic of the rear would be nice too.
Old 30th April 2015, 03:59 PM   #3
Originally Posted by guangui View Post
Very nice and beautiful!.
Thank you!
How it sounds?
Initially I tried to use switching power supply with two outputs +12V for amplifier
and +5V for Raspberry Pi and DAC. The sound noise was terrible. Then I replaced
that power supply by two separate switching power supplies. The noise level is
much lower now but it's still audible in pauses. So I'm going to replace +12V
switching power supply by a linear one. The problem is to fit it (mostly transformer)
into the limited space which I have inside of the case.
The square holes were roughly cut on scroll saw and fine tuned manually by small
files. More pictures (including the rare views) you can find in the other thread which
I created for hardware and software rather than woodware
http://www.diyaudio.com/forums/pc-ba...-pi-radio.html
Old 1st May 2015, 02:32 AM   #4
Nice!
Old 11th May 2015, 04:53 PM   #5
Nice!
Thank you guangui!
Here is the next stage - applying boiled linseed oil.
I'll let it dry for a week and then I'll apply amber shellac.
Old 9th June 2015, 11:00 PM   #6
And finally the image after shellac applied:
Old 9th June 2015, 11:07 PM   #7
chrisb is offline chrisb
gorgeous piece of handiwork - more patience than many of us monkey coffin hacks can manage
Retired from active DIY
Old 9th June 2015, 11:11 PM   #8
Just one word...WOW!!!
My ADD doesn't allow me to wait that long.
Old 12th June 2015, 08:59 PM   #9
Thank you guys!
Old 12th June 2015, 10:48 PM   #10
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Woodware
rpi,
Very nice.
http://www.evancotler.com
WoodwareHide this!Advertise here!
Copyright ©1999-2019 diyAudio
