Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Clubs & Events Audio related organizations and events |
Thread Tools |
#151 |
I will be attending from Concord... Is there anyone in my area that is going that either needs a ride or that I could follow so I don't get lost? I have a Hyundai Genesis Coupe that can carry stuff to the show if needed too.
#152 |
I'd like to hear your Mets. I remember the 8" Hemptone Mets from the 1st Burning Amp. They captivated the audience in the firehouse. IIRC they were powered a tube amp built in an upside down basting pan... They sounded really good!!!
"Only those questions that are in principle undecidable, we can decide." - Heinz von Foerster Ethics and Second Order Cybernetics |
#153 |
I'll be attending and can volunteer to help set up, too.
Looking forward to it! Cheers, David |
#154 |
Does anyone have a good radio lapel microphone?
I have studio microphones only for PA
!!!Warning!!! Single Ended Class-A-Holism is addictive!!! |
#155 |
I have a couple. However, they are hardwired, not wireless and they are XLR needing power.
#156 | |
A handheld mic would be a good idea as a backup. |
#157 |
INFO - ROOM ASSIGNMENTS - WHERE TO FIND BA - TICKETS
There will not be any signage at Fort Mason that will help you find Burning Amp, so please pay attention to the following information about HOW TO FIND BURNING AMP AT FORT MASON. MAPS I have attached two maps. Please look at them
Please read the previous bullet point for info on where to buy tickets. Entry cost is $20, lunch is $10. Vendors and speakers get free ENTRY. WHERE TO FIND BURNING AMP AT FORT MASON Please see the attached map. BA is being held in the buildings circled in red. ROOM ASSIGNMENTS Please carefully re-read the text above for that information. LOADING YOUR GEAR INTO BUILDING C I have drawn in and labeled the ramp on the east side of Building C (see attached map). Go up the ramp to the loading dock and then into the first floor foyer. A small Elevator can be used to bring large equipment up to the second floor meeting rooms. Stairs are located past the elevator at the end of the foyer. If you have small gear that you can carry, please use the stairs to reduce the bottleneck at the elevator. ROOM SETUP If you are demoing equipment/speakers you are responsible for setting up table(s) and taking them down at the end of the show. Tables and chairs will be provided by FM in racks in Building C. In the past these were more or less set up around the walls of each room and this seemed to work well for the most part, but it's not a hard and fast rule. Please leave room around the area where speaker demos will take place so that people who are listening can sit or stand at an appropriate distance. POWERING YOUR EQUIPMENT Keep in mind that there are electrical outlets in the rooms but these may not be near your location. Please bring an extension cord or risk being without access to mains AC. Please double check that you have all the cables, wire, power cords, etc. that you will need. There will not be any spare cables on hand this year and there is nowhere nearby to buy them. PLEASE PREPARE A DESCRIPTION OF YOUR PROJECT Please compose and print out a couple copies of some text that describes your project. You will not be able to be present all the time, and this can give people some valuable info on your project without you having to repeat it over and over. . Last edited by CharlieLaub; 12th November 2016 at 06:06 PM. |
#158 |
diyAudio Editor
Does open carry mean that you could bring a beer in a cooler and leave it in your car and after getting your food, go outside , get the beer and eat on the dock of the bay? If so that's a bit of a breakthrough. And makes it even more important NOT to bring it into either building. The weather is exceptional ATM, and with the Firehouse at ground level it really makes it pleasant to stroll around a bit and walk between the venues.
"The geek shall inherit the earth" 2019 Burning Amp is Nov. 9 & 10 in S.F. Thread here on diyAudio: Burning Amp 2019!!! Last edited by Variac; 13th November 2016 at 06:32 AM. |
#159 |
Ya, right next to Otis Redding!
#160 | |
Last time everything was fine except Nelson running away from both microphones periodically. He is not a singer! :-)
Thread Tools | |
New To Site? | Need Help? |
