Clubs & Events Audio related organizations and events
Greater Toronto Area DIY meetup
Old 4th December 2019, 02:31 AM   #1281
Lo_Tse is offline Lo_Tse  Canada
Thanks! Much appreciated!! It is a regular preamp, so RCA in and out. I can bring a set. Not sure what connectors your test set used.
Old 4th December 2019, 02:43 AM   #1282
rsavas is offline rsavas  Canada
It uses BNC, but I have BNC/RCA adapters.
Old 4th December 2019, 03:15 AM   #1283
ticknpop is offline ticknpop  Canada
Yes I bring my boards, there are several unmodified Haflers there, and the Perreaux 3150 chassis and power supply for a high powered version.
I recapped and CLC filtered the Perreaux‘s power supply so I can’t use the original Hitachi 135/50 devices because now it doesn’t sag enough at full power to stay within the Voltage breakdown limits of the Hitachis. Rails are +/-95 volts.
I have matched sets the higher voltage and current K176/J56 Hitachi devices and a set of the double die TO3 Exicons. The heatsink is drilled for 3 of each device And before some-ones says it can’t work ( Syn08 possibly), remember this amp is 33 years old and had the original output devices still running In it.
Old 5th December 2019, 03:38 AM   #1284
syn08 is offline syn08  Canada
syn08's Avatar
It will work, since these are self protecting lateral mosfets and therefore won’t blow in your face, but I would not hope to get much current out of them. They still have only 1S transconductance, which will drop with the drain current and the temperature.
Old 5th December 2019, 04:13 AM   #1285
It’s going to use Bob Cordell’s new Hafler output stage driver board the Rick has been collaborating with Bob on - to run the shop speakers (100db @ 1 watt) - 2 pairs of them with about 3 ohm minimum load in the bass, most of the time they’ll be running at less than a watt or 2 - except when I play them too loud at Diyaudio meets.
My question will be can I use 3 pairs of the double die 16 amp Exicons to get a higher current output capability that maybe I can’t bias high enough because of heatsink limitations, or stick with the lower current single die 7 amp Hitachis and bias them harder.
Old 5th December 2019, 07:01 AM   #1286
syn08's Avatar
The double dies exicons will simply double the available current, you can think of 3 exicons as 6 hitachis in parallel.
The problem with these laterals is the large idle power dissipation due to the high required bias. It is hard and doesn’t make much sense to bias them under the zero tempco point (about 150 mA per transistors) meaning that 3 exicons will need almost 1A bias. You do the math for the power you have to dissipate before getting 1W of output power.
Old 7th December 2019, 03:50 PM   #1287
Looks like tomorrow is going to be a "warm" day and no snow is expected.
See you guys same time (around 11:30 am ?) same place!!
Allan
Old 7th December 2019, 04:29 PM   #1288
anatech is offline anatech  Canada
anatech's Avatar
Beats the heck out of previous years. I would show up regardless of the weather.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 8th December 2019, 01:24 PM   #1289
wlowes is offline wlowes  Canada
wlowes's Avatar
See you all soon. Walter
Old 8th December 2019, 02:51 PM   #1290
anatech's Avatar
Just waiting for my ride in. See you all soon.
Here he is ...
-Chris
Greater Toronto Area DIY meetupHide this!Advertise here!
Newbie from the Greater Seattle Area skeeter99 Introductions 2 4th January 2011 06:24 AM
Basszilla or Linkwitz Orion in Toronto area? mantisory Multi-Way 5 29th September 2010 03:41 AM
Looking for a serious person in Toronto area rmihai Swap Meet 3 30th May 2010 12:54 AM
Hamfest in Toronto area next weekend TomWaits Tubes / Valves 2 23rd April 2007 02:32 AM
Hamilton/Toronto Area: Anywhere to get LM3875 in person? sardonx Chip Amps 28 26th July 2005 07:32 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
