Class D Design Issues
Old 14th May 2017, 01:27 PM   #101
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Default Output filter perhaps?
I would guess the Behringer uses pre-filter NFB, so the amplitude and phase characteristics of the output low-pass filter directly affect the measured response. The switching frequency isn't likely to be the culprit, except that a higher switching frequency would allow the use of a higher cut-off frequency for the output filter, minimising the effect.
Class-D amps with post filter NFB, such as those from Hypex, greatly reduce the effect, although they can suffer adverse effects if the load is extremely reactive.
Old 14th May 2017, 01:43 PM   #102
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
Yes, it's a pre-filter NFB design using the IRS20957s driver and the switching frequency is one MHz, checked it with oscilloscope..
What happens if I change the output inductor from 21 uH to, let's say 10 uH?
If nothing should exist, the possibility itself that nothing should exist, does not exist!
Old 14th May 2017, 01:46 PM   #103
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Joking Class D Design Issues Class D Design Issues ?
It must be 320-350kHz.Not more.....
Old 14th May 2017, 01:54 PM   #104
Ouroboros's Avatar
1MHz is a very high switching frequency for a class-D amplifier, normally it would be between 300kHz and 400kHz.
You cannot simply change the L or the C in the output filter on its own. The filter needs to be (roughly) matched to the load.
It might be useful for you to download the free version of TINA-spice from the Texas Instruments website and perform a few frequency response tests using a simple sinewave source. You could start with L=22uH, C= 1uF and R_load = 6 Ohms.
TINA is very easy to use and gives you a good insight into how component changes affect things.
Old 14th May 2017, 04:19 PM   #105
JonasKarud's Avatar
Sorry, I misread the oscilloscopes 1 uS/div scale, 400 KHz is a more correct value!
Still high, apparently. Can be the uncalibrated old scope.
Old 15th May 2017, 06:50 AM   #106
basreflex is offline basreflex  Spain
the high noise content in the 10-20khz range could be the smeared difference freq of the two L/R modulators interfering . the idling freqs of the 2 channels should be either synced or at least 30khz apart.
Old 15th May 2017, 08:44 AM   #107
JonasKarud's Avatar
On the output board there's a ferro core with 4 separate windings. See picture and diagram. In my opinion, this will connect left and right channels with each other inductively. I'm familiar with Tina and P-spice, but I think this one will be difficult to analyze/simulate, involving two channels.
I shortened out the inductor with 4 jumpers(see picture), and measured again.
The noise is the exactly the same, but phase went from -180 deg to +180 in the same freq region. The sound now is improved, with more open/airy treble.(but not as good as my beloved Nad M3)
Old 15th May 2017, 09:02 AM   #108
JonasKarud's Avatar
After some more listening, I can tell the sound is very much better!
Old 15th May 2017, 09:28 AM   #109
JonasKarud's Avatar
Time for some serious A/B listening, with or without the inductor shorted!
Old 15th May 2017, 09:34 AM   #110
can you measure the Ch1 and Ch2 idle freqs accurately ?
Class D Design IssuesHide this!Advertise here!
Forum for issues related to the design of Class D amplifiers sovadk Class D 57 13th December 2006 06:45 AM
Copyright ©1999-2019 diyAudio
