been busy so it took a while, my amp8 rebuild stopped here with the new PS. need to scrape up some cash for output PS caps and heatsinks. the main trafo has just dried after soaking in electrical varnish. it was making a whining noise without the varnish as the operating freq is quite low.
Hi
Woow abother cool one!
O that's why it is so shinysoaking in electrical varnish
Congratulations, it seems that you have learnt some layout tricks
Big cores require many turns in order to cover their whole length resulting in a too low operating frequency and high I^2*R losses. I prefer smaller cores because they can easily accomodate as little as 4 or 5 primary turns and I^2*R losses end up being lower.
You don't really need a heatsink, a piece of thick aluminium sheet is ok and it may be bent on both ends to get half of an enclosure.
which one? input and output gnd? via parallel 100R and 100nF cap.
this project got shelved because the DD subs I got weren't a good match to the amp impedance wise and I got a very good deal on a broken amp I was able to fix that was perfect for the subs.
but I might revive this project again sometime in the future just for the fun of it. and install it in a real amp case.
-Necropost warning-
I was hoping it wouldn't end like this but such is life.
I just saw this module mixed in the junk pile and decided to revive it and build a 2ch home amp. I have been gathering and ordering parts, fabricated a new aluminum plate, clamps and heatsink. I was going to build this amp and then post the new unit here as an update after it is completed.
While waiting for the parts, I decided to power it up using two 56V 1.2A PoE switching supplies in series and use it that way to be sure the module is still useable. Not one song later, pop! Driver chip is dead. Only Profusion has some NOS in stock but at that price I could get a complete amp module with SMPS onboard. I guess I'll have to break my promise that this amp will be revived someday.
Well, that's unfortunate. I remember back when you started this thread. I wanted to do somethng similar with my TDA2500 board but never got around to it.
I see the TP2350B on ebay/ali for relatively cheap. I think it would be worth trying to save the amp.
I recently revived one of my long dead Audiosource AMP Seven T amplifiers that had been sitting since around the same time you built this. I was able to modify a TA0103A module to work as a TA0104A since the 104A is prohibitively expensive these days.
There are much better Class-D solutions around now, but I will always have a soft spot for Tripath. That silly little Sonic Impact amp is what got me interested in this hobby and lead me to join this forum.
I looked around, none came up on ali but I got a couple on epay. I'll try and get a friend to order a couple or three so that I also have spares. Thanks for the tip!Well, that's unfortunate. I remember back when you started this thread. I wanted to do somethng similar with my TDA2500 board but never got around to it.
Yeah, I really wanted to bring this back to life just for the memories and these are the last few 41hz t-amps around. I still have an amp1 and amp2 in car amps still built and functional but on a shelf. Three amp32s still working also, and an amp9b working with a DIY soundbar with four 3in square tangband subs and six PR's and a full ranger with active LR crossover.
I'm looking for a Tripath TDA2500. If you have one, I'll buy it off of you!Well, that's unfortunate. I remember back when you started this thread. I wanted to do somethng similar with my TDA2500 board but never got around to it.
- Class D
- Big-t
