Class D Amp Photo Gallery
Thread Tools
Old 8th March 2021, 07:39 PM   #1891
Henry666 is offline Henry666  Germany
The front and back panels are 3mm mdf. Should I leave the safety earth connected to the case? Any advantages? Disadvantages?
Old 8th March 2021, 07:40 PM   #1892
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Originally Posted by Henry666 View Post
Hi, thanks for the reply. I can drill holes in the case. That is not a problem. Is the mains ground needed? Is it doing something connected to the chassis with a screw?
If the case is metal then you connect the case to GND because that ensures that if a mains-connected part touches it, you trip the house circuit breaker. Otherwise the metal part could be live without anybody realising it (until they touched it).
So if the case is not conductive, there isn't really any requirement to connect it to GND because it's not required for protection. However, if the case is not metal it also isn't thermally conductive as I wrote before, and it doesn't shield the circuit against noise either.
So to be very frank: Will it work? Yes, it will. Is it a good idea? No, absolutely not.
DIY projects blog
Old 8th March 2021, 07:53 PM   #1893
levistubby is offline levistubby  United Kingdom
levistubby's Avatar
Connecting the safety earth to a non-conductive case has no effect at all.
Old 9th March 2021, 10:52 AM   #1894
daniboun is offline daniboun  France
Hi amigos,
Just got my new TPA3255 by HanZao.
This module is pretty unknown so I wanted to test it )
Out of the Box the module comes with the below components :
- 8000uf Rubycon YXF serie Low ESR / 50V
- Buffer caps, Rubycon YXF serie as well
- FIlm caps (MKP) Wurth
- SE Input (using Micro JST connector 2.0)
- DIP 8 OP Amps 5532 (updated with OPA1656)
Need to make a listening test before comparing vs others...
But sounds good at the moment. No Pop sound ON / OFF.
The module is really well protected : Yesterday I was tired and I mounted the power supply in the wrong way and the same for the OP amps... The module has automatically put itself in protection mode.
The Micro JST 2.0 connector is not practical for the SE input but I connected it with a JST 2.54 which is more conventional.
The Finished amp :
- Full alu case
- HanZao TPA3255 module
- 350W LLC PSU / 36V / 9.5A
- OPA1656
- Alps volume pot
- PET Cooper Cables
- AC Filter
Next step : updating Buffer caps.... If I have time )
Old 9th March 2021, 05:53 PM   #1895
Hi amigos,
New Purifi amp is now ready with the V2 Buffer. Test in progress with OPA1656 + 1692.
Old 10th March 2021, 03:40 PM   #1896
Hello, does that make the case unsafe to use?
Old 10th March 2021, 03:59 PM   #1897
levistubby's Avatar
This is a photo gallery and so it's not really the place to discuss this important safety topic. I suggest that you start a new thread.
Old 10th March 2021, 06:28 PM   #1898
mamocel is online now mamocel  France
No.
Old 17th March 2021, 06:04 AM   #1899
enio nery is offline enio nery  Philippines
the one witth windows are sanwu tpa 3118 monos and the other one is based on yuan jing tpa 3116 tpa3116.jpg
Old 24th March 2021, 04:55 AM   #1900
NOTADOG is offline NOTADOG  United States
NOTADOG's Avatar
Guess this is the place to show off my TPA3110 experiments.
Here's a little Bluetooth Boombox. First pic is final cleaned up version. A laptop brick plugs into a jack mounted on the back. Speakers are 4ohm. Were super bright/tinny so used a 1R10ufC low pass wired at the terminals. Sounds really decent, high WAF.
Class D Amp Photo GalleryHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
