Class D Amp Photo Gallery
Old 14th April 2019, 11:28 AM   #1401
kees52 is offline kees52  Netherlands
Originally Posted by e_fortier View Post
Maybe you guys should start a new thread for this ?
I have, but saw your tread, so tought let see what is possible.
Next time I stay there, it is not a new direction here.
regards
Old 16th April 2019, 02:05 PM   #1402
Kjeldsen is offline Kjeldsen  Denmark
Remember this is just a gallery thread
http://kjeldsensforbindelser.dk
Old 21st April 2019, 05:09 AM   #1403
Baldin is offline Baldin  Denmark
Baldin's Avatar
Default Plateamp finally installed in my XLS 12" sub
Finally got around to installing my Class D amp plate amp in my trusty XLS 12 inch vented sub.
Amp running +-60Vdc so power around 300 W into 6 ohm (which is more or less what the driver represents though it is called 8 ohm ... Rdc = 4.7 ohm).
It is based on my own implementation of IRS2092 with both pre and post filter feedback, and a buffer input stage. Fets are IRFB5620.
Protection; Over voltage, under voltage, current, DC.
Box tuned to ca 23 Hz, and works really well, no preamp implemented, as I'll be making the ajustments from the surround amp.
The amp is actually placed in the vent, as it is a flat serpentine implementation
At +-60Vdc and 275 kHz, the output coil based on T106-2 gets to around 45-50 deg.
The whte fluff is for the cables not to rattle.
Old 1st May 2019, 06:21 PM   #1404
PiotrL is offline PiotrL  Ireland
Hi
Here is my latest amp. IcePower using 300AS1 and 300A1
Enclosure is from Ghent Audio and custom label from an eBay vendor.
Also a pic of the actual modules.
Special thanks to Joe Bocani for making these amps available to DIYer.
BR
Eric
Hi Eric, can you share by any chance how the DIY community can find those ICEPower modules available for purchase?
Piotr.
Old 1st May 2019, 10:57 PM   #1405
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Hi
I simply bought them from a member of this forum. His forum name is : JonBocani
Hope this helps,
Eric
As always - the last built gizmo is the very best
Old 3rd May 2019, 02:47 AM   #1406
Rainwulf is offline Rainwulf  Australia
Originally Posted by korzhuk View Post
I have been encouraged by friendly comment concerning TPA3255. I done some work without testing this board before. Now it was tested. I present results of test. They are a very trash. I am sad.
Yea something is up with this. You dont get crossover distortion with a class D amp, as its class D, there is no inbetween, either the top mosfet is on, or the bottom one is, and any artefacts in the waveform are the result of the varying time periods of the PWM waveform.
I would do a trace on the signal leading up to the TPA and see what you get.
Old 4th May 2019, 03:02 PM   #1407
Turbowatch2 is online now Turbowatch2  Germany
Just wanted to post a picture of two D-amps with inexpensive SMPS in test configuration.
Both work fine and reliable in this combination. I tested them under load, driving 4 woofers for more than 36 hours at 10V p-p. Nothing gets hot, all temperatures under 45C measured with an IR termometer.
These amps and SMPS are the cheapest you can find at AliExpress and pay with PayPal.
This is NO final installation! They seem to interferr with FM radio somehow, so please use a metall inclosure.
TDA3116 2x50w
TDA7498e 2x100w
Smps 24v 120w
Smps 32v 180w
Old 6th May 2019, 07:30 PM   #1408
maxw is offline maxw  United Kingdom
maxw's Avatar
Here's my build of an SMPS400 and 2x UCD180 with HxR buffers. Enclosure front and rear panels were CNC'd by me. The Aluminium profile is standard 2060 which is available from aliexpress, eBay etc.
You can see some more details here: Enclosure for Hypex amps: 2060 alu profile and CNC work
Old 6th May 2019, 09:59 PM   #1409
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
APEX D200
Old 1st June 2019, 10:48 AM   #1410
mestr is offline mestr  Norway
That is a very sexy box you made!
Class D Amp Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
