Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#1001 |
It maybe took a while but they are good looking...
#1002 | |
BR, Aleš
Universal power supply for LM and LT regulators /// BUY LOW NOISE POWER SUPPLY ///OLDO - Modular open source power supply |
#1003 |
#1004 |
Thanks for the nice comments
![]() skrstic, I'm not sure which sounds better... ![]() It's all very subjective, I have not done any measurements. TDA7498 seems to have a bit more "punch", somewhat "fuller" sound - which is no wonder, as it's twice as powerful, and that power shows. The downside is that it requires a more expensive power supply - although I'm driving it using a "laptop brick" (big one, rated at 20V/6.5A)... I think I might try finding a 24v/5A power source, and see what happens. I wouldn't go above 24V on that one, since it has caps rated at 35V, so.... But, even at 20V, it shows more power than TPA3116. As for "which is better", I don't usually make any claims in that regard, as it's all rather subjective and depends on the experience and preferences ![]() To my untrained ear, the TDA7498 seems a tiny bit better as regards the "fullness" of sound and a bit more punch in the lower frequencies. But, take that with a grain of salt - I'm in no way an expert, nor do I claim to be... Anyway, at the current prices, you can buy one of each, and try for yourself - each of those can be had for about $15 with free shipping.... Denis
Hana-Lab Custom Audio Solutions |
#1005 |
#1006 |
tfboy, that is a real monster
![]() Very professional, hats off!
#1007 |
Thanks den. Yes, at 4ohm, it's 3.6kW of musical power in a 3U tall chassis.
I did spend a lot of time modelling the case in 3D trying to get it all to fit inside, respect minimum spacing for electrical safety, etc. The entire thing is machined to spec and there are one or two minor problems which I'll fix if I need to do another one. My only concern with it is the heat. The UcD modules are quite efficient, but still get a little warm with two stacked onto each heatsink. I've taken some temperature readings with the cover on after using it for an hour, and the heatsinks are at around 65 degrees, which is OK (max is 90), but would probably go higher if in an enclosed cabinet... I've wanted to avoid having to use additional fans for cooling (which wouldn't help if in an enclosed cabinet anyway). I might have to add a thermistor to cut power to protect against overheating... Maybe for large multichannel usage, I might restrict to the smaller UcD180 modules. The heatsinks have holes drilled ready for UcD180 mount points too so it's easy to swap. My next project is integrating with new NCore500 modules which are something else! But I need to do a full PCB design for that. They are even more powerful and efficient though and heat wouldn't be a problem. I love Class D for this very reason ![]() |
#1008 |
#1009 | |
#1010 |
tfboy, no earth at all?
360customs.de - Projects: MAX9709 TPA3132D2 TPA3245/TPA351/TPA3255 - SigmaDSP - CSR8645 - BQ24450 - LTC3784 1200W Multiphase Boost |
New To Site? | Need Help? |
