Litz wire and copper foil
snip
I have a general question concerning litz wire: for experimentation purposes is it possible to take a piece of coaxial cable, and pull out the center conductor/insulator and use the resulting shield as litz wire?
Randy,
no...the small wires must be isolated, but You can use a bunch
of small SF wires
Heinz
Eva said:
Does anybody know a quick source for Litz wire and copper foil (for inductors) in Europe? I'm in sort of a hurry...
want a quick one?? if you got access to a clamp and an electric drill, then your IN..
>>cut identical magnet wires
>>clamp the ends using the clamp....
>> find a way to "hold" the other end of the magnet wires and put it in the electric drill
>> now "let it rip"
>> do it with low RPM only so you can adjust the "tightness" of the magnet wires...
thats it.. i hope you get my point...
an image showing my home made litz... :) been using that in my SMPS.. to reduce "skin effecT" on magnet wires... used thin strands of it.....
hope this helps,
raff
