AD Vs BD Modulation in Class-D
Old 24th January 2019, 12:22 PM   #101
kees52 is offline kees52  Netherlands
Originally Posted by kASD View Post
You need cap between comparator inputs to force BD mode in post filter. Also place your CM inductor at the end of output towards load.
I get in ltspice simulation bd mode not right it is not visible just a fase shifted signal on both ends, when put a resistor over the outputs I get bd modulation but only see it in the current.
Maybe mine knowledge about ltspice is to limited.
I do now with triangles and offset it works fine, but these cause crossover unless I do overlap, this is critical.
regards
Old 21st August 2019, 01:24 PM   #102
I sse this is old, I have in the meantime things done so it works, have now some experience.
regards
AD Vs BD Modulation in Class-DHide this!Advertise here!
Flux modulation 454Casull Multi-Way 71 2nd November 2011 11:21 PM
How many modulation methods in Class D amplifier ? xuhaoz Class D 20 5th December 2006 04:15 AM
Alternative modulation schemes for class d amps Nirav Desai Class D 6 10th January 2005 09:26 AM
Class D Modulation Scheme pokka Class D 7 15th December 2004 07:33 PM
new class D modulation method? sfx Class D 12 6th October 2004 07:02 AM
Copyright ©1999-2019 diyAudio
