Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#611 |
Haha, thanks for your reply Lostcause (who's the lost cause now
![]() Yeah I actually realised my mistake shortly after my last post. I confused 2,2uF with 2200uF thinking people was talking about the same thing. I've gone through this thread a lot lately. Perhaps too many times, as I've seem to become blind to the numbers.. Luckily nothing seems to have been damaged! ![]() I'm gonna try and sort this out tomorrow.. |
#612 |
Ok, I got it all sorted out with 250V 2,2uF films and a new 16V 1000uF (sanyo) for C10. Sounds much better now
![]() But i've got this humm now, probably from my weak unshielded cables.. I'm not sure what wires to use. Suggestions? |
#613 | |
I just finished my first SI mod and i used FKAR PG 2x0,5 from the RCA jacks to the pot and shielded it to the alu enclosure. But i guess any shielded cable will do. I have a question about the C10 cap. In my mod i soldered a 4700uF 48V parallell to the existing one. What will i gain if i removed the original C10 and just use the 4700uF? Thanks, Anders |
#614 | |
I don't remember off hand what the value of c 10 is, but the gain would be whatever the difference between the 2 is. A lot of us have just run them both as you have it now. I think I did replace mine with a rubycon 16v 680 uf cap and added a large off-board Mallory cap as a stiffener. |
#615 | |
![]() So i'll probably be better of adding a second stiffener instead of poking around with the original? Or is the stock C10 cap of such bad quality that it's a good thing to replace it? /Anders |
#616 | |
#617 |
Is there a place where all the mods besides classic & stealth mods are in just one list/spot (like 1 page instead of all over the place) with a link to pics (yea I'm asking a lot) I have been going over this thread of 60 + pages & the links to the other threads & pages.
Just when I think I have it all nailed down, I find some other mod that someone is trying. I have the newer board (blue LED) & no resistor between the LED leads. Currently I'm, running a 10A SMPS dialed in at 13.5V, Stealth mod still w/ stock Vol control (I'm replacing w/ 47K resistors). I rewired with better wire too. Sounds great. I'm currently running a loop from my laptop into the input playing the amp at a low volume to burn it in. I have heard 24 hrs up to 100 hrs are needed. Thinking about getting a 2nd one to run a 8" DVC sub i have hanging around. I have a Rockford Fosgate active crossover that I might use for this system.
If it ain't broke, then fix it... |
#618 | |
#619 |
Having my first T-amp up for modding and have bought some new caps for input and C10. Couldn't get hold of Auricaps so I have found some Jantzen Caps which are bipolar Caps. My questions is can I use them as input caps?
#620 |
Goranarog,
If the Jantzens are film caps in the 2.0 to 5.0uf range, then yes, they'll be fine. FYI check around on the forums; people have done extensive cap tests for this kind of application. calvin14, Computer supplies are not ideal, and I believe they usually put out a great deal more power on the 5V output than on the 12v. In addition they are bulky and noisy, from cooling fans. According to what others have said around here, they don't like to run with no load, either, meaning you may have to add a dummy resistor on the 5v outputs so it sees a load and operates correctly. 12v switching power supplies of the type used for LCD monitors are more compact, sound good and are easily available on eBay. Some of them have a trim potentiometer on the board inside that allows you to crank up the voltage to about 13.2, which seems to get you a tad more ommph. 3 to 4 amps should be plenty of power. --Buckapound |
New To Site? | Need Help? |
