Sonic Impact 5066 Parts List & Modifications
Sonic Impact 5066 Parts List & Modifications Please consider donating to help us continue to serve you.
Old 10th January 2007, 11:51 PM   #411
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Originally posted by Sharkythefrog
"Nice" spelling in a few places in my last post, sorry about that Lostcause... A little bit tired bacause of only 2 hours of sleep last night as a storm came in and ripped parts of my roof away which was a little bit disturbing trying to sleep...
Wow, that sucks. Today we have one hell of a blizzard where I live. These pictures don't show nearly how bad it is:
Old 11th January 2007, 04:53 AM   #412
soundphreak is offline soundphreak  United States
Hi all, I've been lurking here long enough to be thoroughly corrupted with CAI disease (continuous audio improvement).
So far I've built a set of buschhorn mkII's and put the little rs 40-1197 in them, bought two t-amps (one of them by accident due to a back-order) and I recently purchased a pair of fostex 108E sigma's also but haven't decided on a cabinet for them yet. I also ran across an an old 1001 PS1 to use as a cd player.The t-amp sounds pretty good to me as-is through the buschorns so I'm eager to hear the modded amp
First I'd like to thank everyone for freely sharing information here, it sure is good to learn from each others successes and mistakes.
I'm about to try my first mod on an amp and have a couple questions. I've read through the threads a few times and I still am lacking understanding on a couple things. I'm planning on using auricaps, either 2 or 2.2 uf for inputs, and am going to replace c-10 but am unsure what to use there. I've seen several references to panasonic fm caps of various sizes and some using an off- board stiffener also. Is bigger better or is there a limit to useful size ?, and for the off-board cap, what is it's purpose? and if c-10 is a large cap would the other one be necessary? and is the off board cap run in series with c10?, I've studied the photos but can't seem to get it. BTW I'm not an electrician so I am having to "paint by numbers" here. Oh, and where is the best place to buy all these parts?
I'll put some pics up soon hopefully.
I am re-boxing the amp so there is plenty of room for larger caps. So far I have come up with an alps 50k pot and plan to get some binding post's and rca inputs. I also plan to replace the led with a blue one .
Old 11th January 2007, 08:38 AM   #413
Lostcause is offline Lostcause  United Kingdom
Lostcause's Avatar
Hi Soundphreak, PS1 - T-amp - Fostex...Hmmmm Nice!
That's exactly my layout at the moment but with FE207E's in an MLTL.
I have found that listening level makes a difference when choosing power cap/caps. I listen at low to moderate levels and find that too much 'stiffening' with BIG caps actually slows the base response. Higher volume levels and they come into their own with good 'punchy' base.
The best setup is to get two FM's onto the sonic, one on each supply pin, but that's pretty tricky to do so make C10 an ultra-low ESR 1000uf (8mm casing fits but you can get bigger ones in there if you put it under the board).
The trick is to get it/them as close to the power pins as possible, this shows you how to get two in there....
extreme modding!
Then, if you decide to have off-board stiffening then you need to have that as close to the board as possible and keep your leads as short as possible. This one bridges the + & - lines like this:
stiffener
Note that you can connect to the existing holes or jump the power to the + lead of C10, but the latter nulls the switch and leaves the Sonic permanently ON.
I (as well as many others) have found that a buffer/pre-amp is also better with the T-amps.
Happy modding.
Old 11th January 2007, 01:52 PM   #414
Buckapound is offline Buckapound  United States
On stiffening caps in the t-amps:
You can easily get a 680uf 16v cap in the same spot that C10 occupies now, as it's the same 8mm diameter. I used a Nichicon PW(M) from Mouser that was described as "low impedance," and that made a big difference in the bass.
I got a little more bass response by adding a (barely) off-board 4700uf cap, attaching the + lead to the pad where the power switch comes back in and the - lead to the solder-covered ground plane near the chip. That made a small difference. From my reading of these forums, 10,000uf is the top end for any discernable improvement, and may even be a little overkill.
--Buckapound
Old 11th January 2007, 05:38 PM   #415
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Another diagram that I hope might help somebody out there....
Old 11th January 2007, 08:44 PM   #416
Lostcause's Avatar
Another sexy diagram from our hero!
Nice one
Old 11th January 2007, 09:57 PM   #417
Sharkythefrog is offline Sharkythefrog  Sweden
No led but at least half the sound i had in mind from the beginning. At least from half as many channels that I was counting in having sound from. So there is hope for mankind.
I soldered the 0 to the big ground plane on the bottom of the ship and suddenly, there were 13,2V to the + pad, but still no led (who needs that anyway:-) .
Jumped up to Axel12:s room connected the amp with no volume on, connected the power and started the CDplayer - and suddenly sound appears. Nices sound tha n before, but in less channels, which is kind of bad when You start up with only two.
Switching cables around and realize that its not anything wrong before input ore after output of the amp - its in the amp. Except from that minor problem I did find myself listening to a total different sound than before. I still think it has to be burnt in as the mid and hight still needs to soften a bit. But what a differense on the bass side. Pretty stiff and rapid an low.
I really think the setup that I have with 560 uF on C10 and 4700 uF offboard and the rest of the other "standard mod sizes" as pictured in our hero Audio1st last picture could very well go for a "more than good enough" mod.
Audio1st our hero, even the stiffener cap on picture. Everything set for the Pure Newbies - except for the local traning cource in soldering SMDs. GReat job Audio1st.
But still - only one channel . . . any one have any idea of the next step. Measuring somethings (the multimeter is up and running) or unsoldering cable by cable shifting them around to find out where the problem is???
The problems with bridging C04 maybe didnīt turn out great even if it looked good. Who knows
Old 11th January 2007, 10:04 PM   #418
By the way, the roof wasnīt to bad. A few hours of work 10 mtrs up on the top of the roof and a slide down to lets say 7 m off the ground shifting a broken brick will do. Except from the fact that we now also got snow and ice - like You Dcibel. Maybe I just hope for a long winter to fix the roof on a warm spring sunset.
Old 11th January 2007, 10:07 PM   #419
LostCause, does all types of input caps have polarity. I couldnīt find any on the Mcaps that I got.
Old 11th January 2007, 10:11 PM   #420
Lostcause's Avatar
Excellent news....it's looking good!
So now you need to put the multi to resistance 200K setting, and put one end on the amp side of the new input capacitor and the other on the amp side of the input resistor.....20K is what you should see....if nothing, then its the connection or your jumper on C4 or C3...whichever is the dead channel.....which one is dead by the way?
Film/foils don't actually have polarity but it's best to have the inner layer on the amp side....some have indications like lead colour etc......
Sonic Impact 5066 Parts List & ModificationsHide this!Advertise here!
Copyright ©1999-2019 diyAudio
