Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#81 | |
#82 | ||
1. White substance is NOT thermal paste. It's kind of caulk to keep TPA IC in place or so. 2. The opamps were NOT original, compare to sourced at Mouser. 3. I'll try to figure out what's wrong with my board and keep results posted. |
#83 | |
The White substance looks a little like RTV Silicone |
#84 | |
The other picture of the amps boards doesn't have signs of this adhesive. |
#85 | |
See this tear down of a Siglent SDS2000 series oscillocope. There is goop on the SMPS components: EEVblog #1309 – Siglent SDS2000X Plus Scope Teardown+Hack – EEVblog Also Apple TV circuit board: White glue on circuit board Siglent SMPS, below.... Sig1.JPG Sig2.JPG |
#86 |
#87 |
#88 | ||
all pictures simply show caulk on trough-hole components instead of tiny SMD chip on mine photo. The reason to use the caulk/adhesive/whatever - to fix big chunky part in place and/or additional HV protection. However, I'm not PCB design professional like each other in this discussion, I just have some engineering background. |
#89 | |
This silicone was under the bolted down heat sink? Does it wobble, when bolted down on this board? |
#90 |
There is no silicon on the board I purchased as seen by the photo.
It is quite clear these boards are assembled by hand. They don’t appear to have gone through a solder flow machine. Even the SMD components and the main TPA3255 chip appears to be hand soldered. So I am guessing there may be a little gang of people assembling these boards and each will do it in their own way. It appears your board may have the spacer washer also “glued” in place with the silicon. Maybe this was to ensure the heat sink didn’t short out the SMD components under it. There does appear to be quite a lot of solder on some components. Probably just a quick fix !! So for we have 9 pages of comments and some other non-relevant stuff on this thread but very little about Sound Quality and Upgrades !! Still waiting for my order for upgrade components from Mouser to arrive - They ship everything from the US so it takes time !! Also some of the Electrolytic’s I ordered were out of stock so still not going to be able to upgrade as I intended until these parts arrive. .
Aiyima A04 and A07, 3e-Audio DAP1002 and 2 Channel Board, KEF Q10 Speakers. I provide PA equipment for Charities and local Clubs and Societies for their meetings inc. ChudFest. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
yuan jing internet store | audiofan | Vendor's Bazaar | 12 | 12th December 2016 06:46 AM |
yuan jing tpa3116d2 gain control | twomix | Class D | 2 | 24th September 2015 09:14 PM |
Very simple Yuan Jing build (noob questions) | hollowboy | Class D | 5 | 10th September 2015 01:01 AM |
Yuan Jing 6n3 tube preamp power requirements and options | JonesySA | Analog Line Level | 3 | 22nd November 2014 08:49 PM |
Yuan-Jing TDA7492 50W+50W Amplifier | cervelorider | Swap Meet | 0 | 25th March 2014 12:27 AM |
New To Site? | Need Help? |
