Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#71 |
Amp is building.
Lester, the TPA board should not connected to the chassis via the screw, isn't it ? |
#72 | |
Loose sockets will get you in trouble all the time... ![]() Thanks, Pete
Consistency is the last refuge of the unimaginative - Oscar Wilde |
#73 | |
You can connect the heatsink screw to the chassis. The whole amp module is floating, there's no connection from ground to standoffs.
Visit my official online shop at www.jlelectronicsph.com |
#74 | |
![]() Thanks Lester.
#75 |
You will soon have nothing to try
#76 |
#77 | |
BradP... I will be waiting for that.. I've used enough chip-quik & de-soldering wick on Ver 1 ![]() Pete
#78 |
Hi BradP, you need to change the PFFB network values if you will use it for 38V.
The PFFB for 51V will still work but the sound will be inferior compared to PFFB values for 36V. Nice aluminum chassis! Regards, Lester
#79 |
My SMPS outputs 48v
#80 |
Seems great )
I see you are using H2000 case. You should twist all your cables. Nice anyway ) |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
What's needed to build an amp around the 3e Audio TPA3255-2CH-260W EAUMT-0260-2-B? | DaveFred | Class D | 25 | 25th November 2020 06:50 AM |
Upgrade to a TPa3255 for my Trike build. Any for sale? | high5james | Swap Meet | 0 | 24th April 2020 06:37 AM |
amp on/off light for TPA3255 build | macson66 | Class D | 14 | 29th January 2020 11:47 AM |
Error checking TPA3255 and IRS2092 amplifiers | Cradle22 | Class D | 11 | 28th September 2018 04:36 AM |
Preamp between DSP(ADAU1701) and TPA3255 AMP | KidCe | Analog Line Level | 4 | 9th July 2018 07:46 AM |
New To Site? | Need Help? |
