JLE TPA3255 Build and Modifications
Thread Tools
Old 19th July 2021, 11:04 AM   #331
maciekw is online now maciekw  Poland
Originally Posted by JLesterP View Post
It is required for PFFB stability specially on open load condition, it will also remove some grit in high volume listening. (also applicable with other TPA3255 builds)
Hi Lester,
Looking at the PFFB schematic shown in Application Report SLAA788A, we see that the buffer operational amplifiers are not affected by global amplifier feedback. Thus, limiting the bandwidth by adding a capacitor in the OPamp feedback should have no effect on the stability of the amplifier's no-load operation. Of course they improve the stability of the buffer, but on the other hand taking into account the filters used in signal sources (e.g. in DACs) it seems that capacitors are not necessary. Please point out the error in my thinking.
Old 19th July 2021, 11:47 AM   #332
JLesterP is offline JLesterP  Philippines
Originally Posted by maciekw View Post
Hi Lester,
Purpose is to limit the gain at high frequencies. It will prevent high frequency instability at open load conditions since some users might input high frequency into the amp not knowing that the amp cannot handle it. If you are sure that there are no other high frequencies being injected into the system, then the amp will be fine.
www.jlelectronicsph.com
  Reply to this post
JLE TPA3255 Build and ModificationsHide this!Advertise here!
Thread Tools
What's needed to build an amp around the 3e Audio TPA3255-2CH-260W EAUMT-0260-2-B? DaveFred Class D 27 21st April 2021 10:15 AM
Upgrade to a TPa3255 for my Trike build. Any for sale? high5james Swap Meet 0 24th April 2020 05:37 AM
amp on/off light for TPA3255 build macson66 Class D 14 29th January 2020 10:47 AM
Error checking TPA3255 and IRS2092 amplifiers Cradle22 Class D 11 28th September 2018 03:36 AM
Preamp between DSP(ADAU1701) and TPA3255 AMP KidCe Analog Line Level 4 9th July 2018 06:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
