Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#41 |
Well, I guess is good enough for my needs...
#42 |
>Typically an amplifier rated by the seller at 50W amp is only clean to 20 or 30 watts.
I'd assume many of these class-D amp are similar to the distortion profile below. That is, they're pretty good at all levels of power, right up to just before the very maximum. It makes sense; when you hit 100% duty cycle, it's a pretty hard stop. But clean through a little better than 1/2 rated power -
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists. Last edited by jjasniew; 5th December 2020 at 10:50 PM. |
#43 |
Yes thats what I found after reading a lot of stuff related to suggestions in this thread.
Thanks |
#44 |
It is that one.
I have never used the analog input on the ZK-1002 boards I have here, so I can’t comment on how it sounds using that input. I just put one board inside one of a pair of bookshelf speakers with the power going in, opposite speaker out and run them from a phone or tablet via Bluetooth. The decent sound, very low price, and sheer lack of complexity makes it such that I would recommend to try one if you happen to have an extra set of speakers around. Bluetooth 5.0 is comparable to CD quality, and makes for a convenient standalone backup system, or for outside, etc. |
#45 |
It seems you posted in the wrong thread...
#46 |
#47 |
Just want to point out that my main motivation for buying that specific amplifier was that it does not have bluetooth.
Nothing against bluetooth, and often it can be better than having some source of unspecified quality injecting noise, but bluetooth adds delay. Sometimes a noisy source is better than a source that's not synchronious to other things happening, like games or movies in my young daughters specific use scenario. The amp is quite good, most likely the main problem will be the source you connect to it.
Fresh album out now! Official release on Sliptrick Records Also on Spotify or Dynamic 24bit/96khz |
#48 |
I don't need bluetooth in the amp
It's to be used with analog consumer line level outputs |
#49 |
alliexpress ect...: hurlant:
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
What amp would you recommend on a budget? | uzernaam | Solid State | 15 | 10th September 2017 09:46 AM |
Jean Hiraga Superclass A 30Watts why does one need 1.2F caps? | rhythmsandy | Solid State | 27 | 19th September 2012 07:13 PM |
what a LME49811 class A amplifier with 50watts into 4 ohms or more | rhythmsandy | Solid State | 4 | 15th September 2012 10:41 PM |
Recommend resistors with a budget of <$2 each? | wwenze | Parts | 3 | 23rd December 2010 01:28 PM |
What drivers do you recommend.... On a budget | lapoltba | Multi-Way | 14 | 21st January 2007 05:23 AM |
New To Site? | Need Help? |
