TPA3116D2 Power Supply
Thread Tools
Old 12th August 2020, 08:58 PM   #1
Surtsey is offline Surtsey  United Kingdom
Default TPA3116D2 Power Supply
I am currently running a TPA3116D2 using a 19.5v 4.7amp PSU. All speakers are 4 Ohm.
It all works fine.
However, a 24v. 10.4 amp PSU has come into my possession.
Blocked
I've no idea why it's been blocked CCM250PS24.
Are there any benefits in using this PSU, or should I discard it?
Old 12th August 2020, 09:05 PM   #2
stocktrader200 is offline stocktrader200  Canada
the chip takes a max voltage of 30v. The 24v psu will work but with more power output.
I just got 2 boards of this chip for testing 50w *2 100w*1
Old 13th August 2020, 02:04 AM   #3
Joseph1 is offline Joseph1  Sri Lanka
Thats nice. All over the past two weeks I'm testing with the same 2.1 subwoofer board.two stereo channels ok.but the subout is very low since it will deliver around 65-70W on 4 ohms.which is not enough for me.I got to know the subout is mono parallel.
Old 13th August 2020, 03:48 AM   #4
Rob43 is offline Rob43  United States
I didn't spend much time looking at all the specs of the CCM250PS24, but from what I did see it looks like a great PSU.
Here are some quick thoughts:
1) Texas Instruments lists a MAX voltage of 26 volts for the TPA3116D2 chip, I'd personally run it at ~90% so roughly ~23.4 volts.
2) The CCM250PS24 looks to have about +/- 3% voltage adjustment, you'll need to adjust it almost all the way down. Please use your multimeter.
3) Enjoy...
Rob43
File Type: png Screenshot_2020-08-12_at_7.30.28_PM_-_Edited.png (100.9 KB, 189 views)
Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD SUMMIT POINT WV 1:24:229 S.C.C.A.
"Chance Favors The Prepared Mind"
Old 13th August 2020, 12:48 PM   #5
Thanks for all the advice. I think I'm going to stick with the original PSU. I don't need the extra power. It seems like a lot of work for +4db.
The target of my original project is 'Outdoor Barbecue Systems' that plug in to lighting circuits. Traditional lighting rings are designed to accommodate the power draw from incandescent lighting. With the advent of fluorescent and LED lighting there is redundant headroom in lighting circuits. I want to build something for a garden, where you can plug in your phone - with a power consumption below 100 watts.
The new power supply is superfluous.
Old 13th August 2020, 07:29 PM   #6
FauxFrench is offline FauxFrench  France
24V supply will only give you more power and a little higher sound-level. On the negative side, a bit more chip heating.
Looks like a really nice power supply. But the price I see is also pretty high. Use for another project.
Old 22nd July 2021, 08:49 PM   #7
gasolin75 is offline gasolin75  Denmark
Hi in another thread i mentioned i have bought a Fosi Audio BT20 A TPA3116d2 based amp and i like it
No pop noise on/off, very fast to get sound out of the littel box relative to turning it on/of, not noise adjusting the bass,treble and volume, flawless bluetooth
I just which to buy a linear power supper 6 or 6.75a and 24 volt, one of those you just plug the power cable from the linear power supply to the amp and a power cord to the back of the linear power supply and into a wall socket, i just can't seem to finde one, is there any one who know of such a power supply ?
  Reply to this post
TPA3116D2 Power SupplyHide this!Advertise here!
Thread Tools
TPA3116D2 2.1 power upgrade xaphan Chip Amps 1 25th January 2020 12:47 PM
TPA3116D2 Power on - Pop Thud Crack bradleypnw Class D 0 1st August 2019 01:35 AM
TPA3116D2 in PBTL Mode, running 4 Mono Boards on one Power Supply Turbowatch2 Class D 34 10th April 2018 11:24 AM
TPA3116D2 2.1 amp. power on/off pop henneberg Class D 1 26th February 2017 04:33 PM
Minimal power supply for tpa3116d2 Ensoniq Class D 2 4th September 2014 07:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
