TPA3221
TPA3221
Thread Tools
Old 23rd April 2021, 01:31 PM   #81
peroz is offline peroz  Slovenia
I need dual stereo.
Can't find one just like these JST. I'm guessing it is a 3,96mm pitch? I'll just get some thin enough not to bump into anything and use them.
Old 28th April 2021, 09:35 AM   #82
bushellj is offline bushellj  United Kingdom
Originally Posted by gigigirl View Post
OK, Sorry for dumb question. But why does the TPA3255 use teo Op-amps, but from what I can see the 3221 does not?.
Cheers
The TPA3255 requires balanced inputs and the two Op Amps are usually included included to convert an SE Input signal to Balanced to drive the amplifier chip. They also provide a buffer / Pre Amp stage that may be required for low level signals often provided by consumer sources. The TPA3255 is expecting to see about 2 volt input signal.
The TPA3221 can accept either Balanced or SE inputs directly so does not require Op Amps to drive the amplifier chip. Also the TPA3221 has more gain so can work with lower input signal levels.
The TPA3221 is aimed at “Consumer” products with the lowest component count whereas the TPA325x is more aimed at professional / Audiophile products and requires more external circuitry and power supplies in order to produce a working amplifier.
Aiyima A04 and A07, 3e-Audio DAP1002 and 2 Channel Board, KEF Q10 Speakers.
I provide PA equipment for Charities and local Clubs and Societies for their meetings inc. ChudFest.
Old 28th April 2021, 09:50 AM   #83
daniboun is offline daniboun  France
It is true but both chips can work on the same way.
My TPA3221 dual mono is using some OPA1652.
You could imagine a TPA3255 with a bypassed Buffer, some DIYers already did it.
TPA3221 :
Old 29th April 2021, 08:57 PM   #84
hansueli is offline hansueli  Switzerland
Hei guys just found this new amazing tpa3221 finished amp
US $166.00 50%OFF | Fever digital power amplifier TPA3251 ultra-clear HIFI digital power amplifier, high power and small size
Fever digital power amplifier TPA3251 ultra clear HIFI digital power amplifier, high power and small size|Home Automation Kits| - AliExpress
Old 29th April 2021, 09:08 PM   #85
It is not a TPA3221 but 3251, I already shared the link )
A few month ago you could buy the module @ 50 euros ! the price of the finished amp makes non sense for me !
Old 10th June 2021, 08:56 PM   #86
notakosan is offline notakosan  United States
How does TPA3221 compare with dual TPA3116? I haven't found much information in terms of this comparison.
Old 22nd June 2021, 10:26 AM   #87
vilding is offline vilding  Sweden
Hi! I bought the Sunbuck tpa3221 module to test outfor an upcoming active speaker build for a family member. I really, really like the amp! It sounds very good. Crisp and clean deep bass, very nice even fr and great imaging and dead quiet when not fed a signal. My only gripe is the big pop when turned on. Does anybody have an idea as how to mitigate this? I like tinkering but i have literally no usable knowledge of electronics... I drive it with a 24vdc MeanWell wall wart.
I tried with a cap in the rest/mute position which worked great with the same looking TPA3255 card, but no good.
Photos show that part of the board and it seems not mostly unpopulated.
Btw: It leaves the TPA3116 far, far behind it imo. Just does everything better.
rlrr lrll
Old 22nd June 2021, 01:37 PM   #88
denbret is offline denbret  Canada
denbret's Avatar
For those who haven't seen it.
Half price of the other linked above
Fever digital power amplifier TPA3221 high-definition high-power HIFI power amplifier
Fever digital power amplifier TPA3221 high definition high power HIFI power amplifier|Home Automation Kits| - AliExpress
  Reply to this post
TPA3221Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
