TDA7498E don't produce any sound (red Amplifier module)
Old 18th May 2020, 02:26 PM   #31
manojtm is offline manojtm  India
manojtm's Avatar
If i'm not wrong reading the circuito, this capacitor you say is on the position C16 of the circuito, right?
I test it with my DMM and this is not damage.
PIN-29 check the volt with DMM it should be 1.8v~2v if not replace capacitor with new
MANOJ
Old 18th May 2020, 02:34 PM   #32
Jorgesilva is offline Jorgesilva  Portugal
MANOJ
Do i need power up the TDA7498E with 12v or 24v for test because i need remove the heatsink, you say this in other post, right?
For measure the PIN29 i need the DMM and connect the black terminal on GND in of the power supply of TDA7498E board and the red terminal on PIN29, right?
Old 18th May 2020, 02:36 PM   #33
manojtm's Avatar
yes and PIN 21,22 also
MANOJ
Old 22nd May 2020, 01:51 AM   #34
MANOJ
Hi my dear NANOJ, i hope you have an nice day.
Yesterday i power up my TDA7498E without testing the PINs you say for i test but the amplifier board work for about 5min. and know it don't give any sound.
I don't understand why this happen but the IC is not damage.
I suspect the amplifier shutdown because the standby or mute.
Can you give me a help without testing the PINs first?
The pins it's to small and i hope don't short anything when i test the pins.
Old 22nd May 2020, 07:10 PM   #35
MANOJ
Today i test the pins you say to me, and i supply the module board TDA7498E with 12v.
I test the pins from the GND of the power terminal of the amplifier and this is my values from the pins (DMM measure DC Voltage):
PIN 20: 0.00
PIN 21: 0.00
PIN 22: 0.05
PIN 29: 0.00
The VCC PIN os reading 11.7v.
I hope my pins is right, but you can see on the picture if my schematic is righ!
If you can give me some help.
Best regards
Old 23rd May 2020, 01:56 PM   #36
manojtm's Avatar
you counted wrong direction i think
you can see a dot mark (punch) on IC
MANOJ
Old 23rd May 2020, 02:35 PM   #37
MANOJ
Thank you for correcting me my dear NANOJ.
I'm using DMM correct? I put the black terminal of DMM on GND terminal of power supply of TDA7498E and red terminal i use to measure the voltage on PINs, is this the right way to measure the PINs?
Sorry to asking you all this stuff, but i don't have to much knowledge on that.
I was trying to count the PINs using the datasheet schematic for the TDA7498E.
I will test the PINs (20, 21, 22 and 29) again and re-enter their values.
Meanwhile, can you Share the values of this PINs for i can compare with the values of my PINs?
Thanks a lot for the help.
Best regards.
Old 23rd May 2020, 07:17 PM   #38
MANOJ
Hi again my dear NANOJ, i hope you have an nice day.
This time i measure the PINs of my TDA7498E the right way, use your picture as reference and this is the values from the PINs of the IC:
PIN 20 = 0.96v
PIN 21 = 3.15v
PIN 22 = 0.13v and the voltage drop to 0.08v
PIN 29 = 0.00v
I supply the module board TDA7498E with 12v for measure the PINs of the IC.
I don't know what is the problem for this amplifier board TDA7498E don't work.
Can you give me some help?
Big thanks.
Best regards.
Old 24th May 2020, 02:23 PM   #39
manojtm's Avatar
PIN 20 = 0.96v
PIN 21 = 3.15v
PIN 29 = 0.00v
PIN 20(STBY) & 21(MUTE) should be minimum 2.5v{pin 21=3.15v is ok} and pin 20=0.96v may be it is taken to High(because 0.5v= low) but PIN 29=0v is low it should be 1.8v.I already said replace 10uF capacitor with new
MANOJ
Old 25th May 2020, 08:00 PM   #40
PIN 20 = 0.96v
PIN 21 = 3.15v
PIN 29 = 0.00v
MANOJ
Can you give me a help?
Is that capacitor i mark on picture i need to replace?
Other question, i measure the outputs speakers from the amplifier and it's reading DC voltage on the outputs. This is the values from the outputs speakers from the amplifier:
Left channel: 1.18v
Right channel: 0.68v
I know this values (DC voltage) from the amplifier in outputs speakers can damage my speakers, right?
I hope you can give me a help.
Many many thanks for your time.
Best regards.
TDA7498E don't produce any sound (red Amplifier module)Hide this!Advertise here!
SMSL SA-98E TDA7498E , What's your opinion of its design\sound ? WhiteRhino Chip Amps 3 21st October 2015 09:51 AM
Which company produce high end pure digital amp module? mbl Class D 0 3rd March 2010 06:44 PM
You PC amplifier can be modified to produce better sound destroyer X Solid State 11 12th October 2008 01:00 PM
Why can't sound produce light? tomasro Everything Else 62 1st February 2004 02:00 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
