Give me a few minutes. I’ll make you a diagram.
I shared a simple picture above )
If you want to learn please follow directions. measure your PSU first. red and black marks on green plastic not enough.
OK, done for the first learning :
It should be like so ?
Yes. Hooray!
Let's try lol...
if you can't see me here anymore ... it's because I burned with the amp
Let's try lol...
Most of us burned a ton of circuits, I know I`ve had. Yet we keep coming back.
Hi Dani,
The power supply seems OK. Left if minus, mid is ground and right is positive.
For the amplifier board, scroll down a little and you can see the power connections ( WONDOM AA-AB32321 IRS2092 Module amplificateur stereo class D 2x125W 8Ohms - Audiophonics ).
No reaction of the amplifier with these connections?
Hi amigos, first : let me say THANKS for your help... That was my first double Rail PSU, unsually I do not use those kinds of power supply.
Here the final result, seems to work fine. I am still listening to my HD Audio music and I will let you know my feelings about the Wondom IRS2092
- Class D
- [Amplifier IRS2092 / IRFB4227] HYY-01 questions
