Infineon MA12070 Class D
Thread Tools
Old 14th October 2021, 01:43 AM   #511
Michael Xiao is offline Michael Xiao
Originally Posted by Yatsushiro View Post
Does this work?
The burned IC is CH224K and I had explained the reason why it will be burned in the last reply. For this board, First you can remove the burned IC and check the 5V power supply, then check the MA12070Pís IO haven't breakdown by Rpi.At last please confirm the max voltage is 20V, if you remove the CH224K firstly, you can put 24V.
Old 18th October 2021, 11:52 AM   #512
maciekw is offline maciekw  Poland
Default long cable
Hi Michael:
I have a question for you: with long speaker cables (5-6 meters) should I use additional output EMC filters for your amplifiers?
I want to use your amplifier modules to power my surround speakers for my home cinema.
Old 18th October 2021, 03:47 PM   #513
ernperkins is offline ernperkins  United States
ernperkins's Avatar
In case you haven't seen it, here's the Infineon app note on using filters. It should answer your questions.
Old 19th October 2021, 07:07 PM   #514
@Ernperkins:
Thank you for the linked document. However, while looking at the module board, I noticed that there is already a simple EMC filter on it under the heatsink. And when asking the question, I meant is it sufficient according to the board designer to remove the interference emitted by the longer cables?
Old 22nd October 2021, 11:22 PM   #515
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
Originally Posted by Michael Xiao View Post
I'm the designer with PL-AD-150 from Shenzhen PILLOR, any problem or suggestion let me know, and I will answer it try my best, thanks!
Hi Michael,
Thanks for posting here.
Maybe others like me don't know how these boards come to life, would you be able to explain the journey, please? I searched for Shenzhen PILLOR when I first got my boards but found nothing.
Is it a design made just for the DIY market or did it have an intended market purpose? Knowing the back story, research and development would be fascinating.
Cheers!
G.
Old 23rd October 2021, 08:17 AM   #516
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
The picture shows damage to an 8pin SOIC IC which the markings look to say 'MP1593DN' - this checks out as a 3A buck regulator. The CH224K is a 10 pin package nearer to the USB input. The MP1593 has a max input voltage of 28V.
The whole problem... is that fools and fanatics are always so certain of themselves while wise people are full of doubts. - Bertrand Russell
Old 27th October 2021, 07:36 PM   #517
horika is offline horika  Hungary
Hello Guys. I got my module with MA27070P chip. can I put an i2s signal directly on its input? I use amanero.
amanero Outputs: data, bclk,lrck,mlck, grn
ma127070 inputs: sck,ws,grn.sd0,sd1
which one where?
mute pin? eneble pint?
i didn't get any documentation for it.
can somebody help me?
thx.
Old 27th October 2021, 09:04 PM   #518
this is not the rpi version. it does not have a 40pin connector
Buy Products Online from China Wholesalers at Aliexpress.com
Old 27th October 2021, 09:41 PM   #519
mboxler is offline mboxler  United States
That link just gets me to a login page.
Old 28th October 2021, 07:33 AM   #520
sorry.
High Quality HIFI Digital CLASSD Power Amplifier Module MERUS MA12070 2X80W 1.4 Version|Instrument Parts & Accessories| - AliExpress
Infineon MA12070 Class DHide this!Advertise here!
Thread Tools
Infineon IPA50R140CP N-channel mosfet exeric Tubes / Valves 19 29th January 2016 10:21 PM
Infineon sab2403 digital input! class D melis Chip Amps 6 17th December 2014 10:41 PM
Infineon ICE3B1565 phoo1234567 Parts 0 12th September 2008 06:31 PM
Infineon BTS5215 and similiar IC's peranders Parts 3 19th June 2004 09:55 PM
Infineon Power parts -- where the h??? can I get them? Petter Parts 0 24th March 2003 04:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
