Infineon MA12070 Class D
Thread Tools
Old 13th October 2021, 08:07 AM   #501
Yatsushiro is offline Yatsushiro  France
Originally Posted by Michael Xiao View Post
I'm the designer with PL-AD-150 from Shenzhen PILLOR, any problem or suggestion let me know, and I will answer it try my best, thanks!
Are you also the designer of the PL-DD-140W board? I have two of them, the first of which blew when fed with 24V DC, taking the attached RPi down with it.
Can you confirm that the V1.3 board is safe to be fed with 24V DC? My second board is currently running at 12V, I will try 18V next but am a bit wary of going to 24V in case it blows again.
Old 13th October 2021, 08:45 AM   #502
Michael Xiao is offline Michael Xiao
Yes, PL-DD-140W was designed by me. The board's recomand max voltage is 20V, over 22V will burning CH224K(absolute max voltage is 22V) maybe, and other ICs are support max 26V, so if you want put Vin 24V, you can remove CH224K(If you remove CH224K, the cost of it is that you connect the board with PD charger by Type-C connecter will remain 5V). On the other hand, I need you confirm if your board was burned CH224K or not, if the other IC was burned , so it will be the other questions. And I'm very sorry for bring to you some misguide at the board's silkscreen(26V).
Old 13th October 2021, 09:22 AM   #503
maciekw is offline maciekw  Poland
Hi, is it possible to connect three modules PL-AD-150 to one SMPS? This question has been asked before but remained unanswered.
Old 13th October 2021, 09:34 AM   #504
Do you mean parallel three modules at VIN & GND with one SMPS? If it is. It's OK, and I can't list any reason to explain why it can't, or you can recomand me some potential mistake or damage.
Old 13th October 2021, 10:08 AM   #505
Thank you for the clarification.
Old 13th October 2021, 11:00 AM   #506
Hi Michael
Thanks for your reply. The photos below show the component that obviously burnt; I can't see any other damage. When it burnt, it also damaged the attached RPi beyond use.
I like to use laptop PSUs or 18V powertool batteries, so will not exceed 20V.
Old 13th October 2021, 11:18 AM   #507
Can you advise whether the procedure defined in Section 4.5.2 of the attached document should be undertaken when using PL-DD-140W?
https://www.infineon.com/dgdl/Infine...6eef8084096be6
Old 13th October 2021, 07:24 PM   #508
zek is offline zek
zek's Avatar
Originally Posted by Yatsushiro View Post
.. The photos below show the component that obviously burnt; ....
There is no photos...
Old 13th October 2021, 08:03 PM   #509
Does this work?
Old 13th October 2021, 09:55 PM   #510
Solve is offline Solve  Sweden
Solve's Avatar
"Find a setting that gives you a smaller image, e.g. 640x480, 800x600, 1024x768. No need to go bigger. 800x600 and 1024x768 and good sizes for this forum."
Size Matters! Posting images to the forum - diyAudio
Music is the only art in real time....
Infineon MA12070 Class DHide this!Advertise here!
Thread Tools
Infineon IPA50R140CP N-channel mosfet exeric Tubes / Valves 19 29th January 2016 10:21 PM
Infineon sab2403 digital input! class D melis Chip Amps 6 17th December 2014 10:41 PM
Infineon ICE3B1565 phoo1234567 Parts 0 12th September 2008 06:31 PM
Infineon BTS5215 and similiar IC's peranders Parts 3 19th June 2004 09:55 PM
Infineon Power parts -- where the h??? can I get them? Petter Parts 0 24th March 2003 04:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
