Class D with above 2.5Mhz output?
Old 4th December 2019, 03:12 PM   #1
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
Default Class D with above 2.5Mhz output?
Is there any class D amplifier that is fast enough to have 50V/us or above? So i am expecting the output pwm is beyond 2.5Mhz.
So i am looking for an chip Class D that able to work over 200khz, and if possible DC output too!
I have bought some irs2092, TPA3255, but their output is just around 400~500khz.
Attached is the output that i wish to generate, and the load will be very low.
I have tried to drive with 4xparallel LME49600, surprisingly they cant do the job.
Old 4th December 2019, 05:29 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
My simple design runs at 280KHz without any truoble.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 4th December 2019, 06:41 PM   #3
Mark Tillotson is offline Mark Tillotson
That's GaNFET territory I think.
Old 4th December 2019, 07:33 PM   #4
MorbidFractal is online now MorbidFractal
Looks very much like you are trying to recreate the drain waveform on a single/two switch forward/flyback convertor?
Old 5th December 2019, 01:02 AM   #5
I am considering Ganfet too...
Old 5th December 2019, 01:03 AM   #6
It is for piezo actuator use.
Class D with above 2.5Mhz output?Hide this!Advertise here!
Major difference between class A and class AB output (and proper AB biasing) easphyx Solid State 9 30th October 2016 07:20 AM
Bias voltage for Class A/B output and output transistor choices maggiesnmacs Solid State 20 6th May 2016 04:26 AM
Allison Biased Class A Amplifier with Rail to Rail output and acceptable Class AB GregH2 Solid State 5 18th November 2014 03:58 AM
LM4702 or LME49810 work in class A mode to drive the output stages in class A/AB rhythmsandy Chip Amps 29 29th December 2012 12:54 PM
Can someone tell me why this transistor's Ft is only 5MHz!? keantoken Solid State 19 3rd October 2010 06:13 PM
Copyright ©1999-2019 diyAudio
