Amplifier DIY kit recomendations
Amplifier DIY kit recomendations Please consider donating to help us continue to serve you.
Old 21st October 2019, 10:15 AM   #31
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
Thanks FauxFrench and Turbowatch2, wonderfully comprehensive explanations!
Old 28th October 2019, 10:48 AM   #32
Kjaerlarsen is offline Kjaerlarsen  Denmark
So, when building up this amplifier, is there any way to control it via some sort of signal?
My surround reciever has a 12V output for switching on and of external amplifier.
Some sort of relay (solid state?)? or is ther something useable on the circuit board itself?
Another thing is, what if I leave the amplifier on all the time, what will happen when the preamp switches on and off?
Old 28th October 2019, 03:08 PM   #33
kartino is offline kartino  Indonesia
kartino's Avatar
Originally Posted by FauxFrench View Post
Hi Kjr-Larsen,
TPA3255 is one of the best chips.
And it is designed to allow post filter feedback (PFFB)!
This the big difference with other chip.
Old 28th October 2019, 03:11 PM   #34
kartino's Avatar
Originally Posted by Kjaerlarsen View Post
Hi.
B so I guess more than 150W/8 Ohms would not be needed.
So then UcD180 from hypex is the best for this application.
Old 14th November 2019, 05:15 PM   #35
All parts finally arrived.
Time to drill some holes!
Or should I make a quick mock up to test that everything works?
File Type: jpeg AA4EF842-B9EF-47B7-B1AD-951084AE8C1B.jpeg (354.2 KB, 333 views)
Old 21st November 2019, 01:37 PM   #36
Getting there.......
File Type: jpg BBADF868-4B53-4B17-9E55-E276AA801AC4.jpg (713.3 KB, 266 views)
File Type: jpg 1A071F6C-ED06-4442-A4E8-7C665B11B4B0.jpg (671.5 KB, 263 views)
Old 21st November 2019, 03:49 PM   #37
Got to test the amp with a set of speakers in the basement. And everything works, and plenty of power. No noise at all, except for the cooling fan for the power supply. Quite noisy, even though stated that it is temperature controlled. So took the lid off.
Going to hook it up to my stereo tomorrow. Going to be interesting to hear the sound quality.
File Type: jpg 4BD32220-7C27-4981-9B34-D7997CD6CE5F.jpg (796.5 KB, 244 views)
Old 24th November 2019, 06:02 PM   #38
Got time to spend a few hours listening on my stereo.
First impressions are good. Theres absolutely no noise of any kind. Low end is deeeeep and very well controlled and tight! Midrange is okay, not quite as detailed as my Rotel amplifier, but not bad at all. High end lacks a little detail but quite neutral. Sound stage is not as wide and deep as I could wish for, but it does nothing wrong, just not quite up where I would have liked it to be.
But considering the building cost of around 200 it certainly performs well!
Im considering building a new amplifier using the Hypex ucd180hg modules, I guess I will get the details and soundstage Im looking for.
Old 25th November 2019, 12:09 AM   #39
denbret is offline denbret  Canada
denbret's Avatar
Hello,
it joins my own appreciations.
This amplifier can be improved with the change of the OP (not try again), so I think that changing the SMD link capacitors, by better capacitors should bring what is missing as sound.
Old 25th November 2019, 04:53 AM   #40
Originally Posted by denbret View Post
Hello,
Thanks for the advice. Where are these SMD capacitors located? Is it the four sitting next to the coils?
Sounds like a manageable tweak.
Amplifier DIY kit recomendationsHide this!Advertise here!
some power amplifier recomendations cd-i Solid State 88 29th December 2013 06:44 PM
recomendations please falcoron Full Range 3 26th July 2011 02:19 AM
first diy dac recomendations? skvuppla Digital Line Level 2 26th May 2009 02:57 PM
Best amplifier (recomendations) for Fostex FE108ez? Guijs Tubes / Valves 4 2nd October 2005 06:38 AM
DIY Sub amp recomendations?? .::Jonesy::. Chip Amps 17 19th January 2005 07:36 AM
Copyright ©1999-2019 diyAudio
